when i start my car, it shakes and vibrates like crazy at idle (standing still) could worn motor mounts be the cause of this??i know i need new drive axles, but i don't know why the car would still shake when it's just idleing...
any suggestions would help
Could worn motor mounts cause car to shake at standstill?
- solo_ryder
Re: Could worn motor mounts cause car to shake at standstill?
Yes, that would certinally cause that, also bad timing or spark can cause that
- 94mx3precidia
is it idling at the proper speed? a slow idle can cause the car to vibrate as well.
1994 MX-3 GS KLZE, Probinator, Bully stage 1 (probe GT), B&M Short Shifter, 2 1/4" Custom headders back.
- nsklzemx3
Look at the engine when it's idling and see if it's shaking!
'93 MX3
A work in Progress
CURENT UPGRADES: Curved Neck KLZE/Option Import Headers/2.5" Exhaust/Valeo OEM Clutch/Yonaka Motorsports Gaskets & Silicone Tubing/Option Racing CAI/MBX Probe Addiction Wires/Fidanza Flywheel
My Aloha 8.2: http://s162.photobucket.com/albums/t258/1981aloha27/Aloha 8.2
Matilta 20
Cygnus 20
Code 40
A work in Progress
Matilta 20
Cygnus 20
Code 40
Thanks for your responses
The engine chugs pretty badly, it seems to be missing..i guess (like you said) due to timing or spark, i'll try new plugs and wires first
Engine doesn't appear to "shake" other than the chugging
