after O2 sensor changed... now idles wierd...
- PWRD_BY_HKS
uhhhh... im a little confused .... i changed my o2 sensor ... and my oil .... and added some tranny oil..... reset my computer (kl31)...and now my idle dropped ... i use to idle at 1,300 rpm.... now im like at 900..... is this normal... my old sensor was bad.... this one is new ... universal but new....
all help is appreciated as usuall ... thanks...
jdmx-3 KID OF THE ![Image](http://img118.imageshack.us/img118/8885/3kidkn5.jpg)
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
Re: after O2 sensor changed... now idles wierd...
i suppose you have a KLZE , i think 1300 is to much, the same for 900 rpm. The k8 engine have normal idle at 670 rpm +30 or -30, i have a KFZE , idles around 600 or 700 .
Marius.
Marius.
'92 Black Mazda Mx-3 - kl-ze
I wish my idle was that low :/
whenever i try tolower it the car just stals because its to rich. :/ i think its good that it idles that low for you.
as for me i let it like that since my o2 sensors wont matter in a few weeks when i install my megasquirt.
-hec
- PWRD_BY_HKS
okay yes... idle ... not the subject.... is it normal for it to do that.... after changing o2 sensor..... is it normal for my idle to change.
VICTORIA RACING
VICTORIA RACING
- mr1in6billion
If the sensor was dead i'm not surprised the idle changed when you put a new one in. Plus, why does it matter? Your idle is a lot closer to normal, that's a good thing. Stop questioning it.
- ElectricEnergy
I... Like.... to use.... lots of periods too......
- William Shatner
- William Shatner
![Image](http://i159.photobucket.com/albums/t148/electricenergy_album/caravatarcopy.jpg)
KL-ZE Swap - OBX SS Headers - 2.5" Exhaust - Falken Azenis Tires - H&R Springs - ZX-2 Struts - CAI - Front & Rear Tower Bar - AWR Motor Mounts - 100hp wet shot (yet to be tested)
- PWRD_BY_HKS
good.... now that we got that down. thanks .... no its not normal for my car.... after i boosted it just doesnt idle smooth unless its over 1,200 but thanks ill just bump it up some....
VICTORIA RACING
VICTORIA RACING
I want to take advantage of this and post a link with my IDLE rpm , it looks low but i dont have any vibrations or neither the engine dies. worked good so far.
http://www.facebook.com/photo.php?pid=2 ... =613685135
rudy.... we ... both knew...... your.... o2 ... sensors.... were dead...... remember .... ???
-hec
