running lean.
- se7en
running lean.
I am running lean.
I am wondering what I can do to fix that.
I have FMU installed, and I am still waiting on my millenia S injectors to get here.
at cruise(part throttle, I am at 11.8-12.2:1 which is great, and at idle, I am at stoich(14.7:1)
but as soon as boost comes on, it goes lean(like way lean, and off the gauge.
I am wondering, Do think the millenia S injectors will fix this? could my stock injectors just be sh!tty?
without the fmu, I can't boost over 1 psi before it goes lean.
now I am at about 2-3psi, and still lean there.
I am hopeing thast the millenia S inj. will let me boost to 7-9psi.
what do you think???
will the millenia S 's fix my prob or what?
thanks
7
EDIT : it is the worst in first and gear.
third gear will pull about 13:1 until 3-4psi, then go way too lean.
and forth gear is not bad until about 5psi.
geez, I can't wait until my injectors get here. I hope that fixes my problem.
thanks
7
- XxantwawnxX
the fmu might be overloading the small injectors...cause them to go static. wait it out man to u get soem bigger ones. or ditch the FagManagmentUnit.
- Limegreen mx-3
i couldn't say it in any better wayXxantwawnxX wrote: ditch the FagManagmentUnit.
because thats what they are POS FMU
im not dissing u se7en im dissing the fmu
- se7en
I know, I know, but I just needed something to raise my fuel pressure for the time being.
I am msns soon so then I won't have to worry.
7
7
i ran 220cc injectors with a high pressure fuel pump on my k8 and it was as close to perfect as u can get with no managment at all...
http://www.cardomain.com/ride/2433610" onclick="window.open(this.href);return false;
mx-3 Kl Turbo (Weekend/show car)
95 talon tsi awd (Daily Driver For Sale 6,000 or Trade for a Mx
1989 Cbr600 (StreetFighter/Stunt Bike)
1967 Winnebago Motor Home (Pimped out Party Bus a friend and I went in halfs on)
1972 gremlin X Turbo Diesel
, 1999 VR4 Fathers Cars that i end up working on and drving alot
- se7en
what psi where you using when it was perfect?
- RbluE_MX-6
With ms all you'll need is some bigger injectors. What are your power goals? How much boost you plan on running? That'll help in determining your injector size. Still millenia s injectors are good for *some* boost.se7en wrote: I am msns soon so then I won't have to worry.
7
How much did the millenia injectors cost?
88 Mx-6 GT FE-DOHC rebuilt
Too much to list...
Too much to list...
- se7en
I got them for about $140 canadian shipped.
I will only be boosting to about 10psi when I get them in the mail.
I will be keeping a close eye on the Air/fuel ratio when I do get them.
also, being that it is winter right noe, I can get away with 10psi for now.
in summer I will be only 7psi probably, unless I have race fuel and I am at the track
7
ps, how much boost are the millenia S injectors good for in the k8 do you all think?
I'd like to push over 200whp with this motor for now until it goes pop!
7
