B6de,boosting it
B6de,boosting it
I have a 1.6l dohc 97 with 118.000klm about 73750miles(at really good condition).I already have a k03 t25 (from a seat leon cupra) and a fmic big enough.Assuming that lowering the compression at about 8.0:1 how many bar/psi should i run it,an how many would be the horsepower?
- hotsiit
No idea what kind of power you could make, but I am / was running a T3 super 60 turbo on my SOHC 1.6l 4cyl stock (North American) motor, at 9psi. The only problem I had was alot of blow-by...basically shooting lots of oil out of the breather filter on the valve cover.
Other than that, the motor ran 9psi fine for years, could probably handle more, maybe?
1993 Mazda MX-3 RS-Turbo
1993 Mazda RX-7 touring
1983 Mazda RX-7 GSL
1987 Jeep Comanche
1983 Mazda RX-7 GSL
1987 Jeep Comanche
osargeant
I run around 11psi on a standard compression B6 motor, it is all about tuning, fuel and ignition control.
I have seen the miata guys run 15/16 psi on these B6 motors with proper engine management and tuning.
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
- se7en
from what I understand from reading on this board, the dohc will handle 10psi with minor mods(fuel manage, timing retard etc) you won't have to lower the compression at all, 9:1 will be fine.
200hp will be easy, and 230 will be not too hard.
good luck!
7
good luck!
7
- Limegreen mx-3
a friend of mine has a lil 94 mazda miata with the 1.6 b6de with a setup simluair to mine.. all the good stuff
what i don't get is that lil b6 can take a beating. at one point i was at 25psi making 334rwhp on a gt32 turbo... now his on a 57trim turbo at 15psi number are not known at this point.
i been through 3 bp's 5 trannys and he still has the damn b6 going on for a year. what gives that b6 can take a beating.
Re: B6de,boosting it
so i bought the parts i wanted (garrett tb02 47trim turbo , 48trim comp),fmic,emanage blue(already installed) with injectors and advance harness,323 gtx injectors and now im up to buy wideband,maybe zeitronix.
besides i decided to lower the static compression to 8,5:1 with a metallic head gasket so i can be sure.
you think 1bar will be safe? and also,before or after the turbo should i put the maf?
- Limegreen mx-3
get rid of that POS e-manage blue. sell it get rid of it or get ur money back..
your better off with a Mega squirt II than a e-manage why..
a e-manage is still a piggy-back and a MS-II is a standalone system.
compression wise u are fine unless u keep ur e-manage
but hey its ur setup..
can't stress how important a EMS if vital to a turbo setup. a piggyback just won't cut it.
you guys need to start giving these motors some credit.
My b6t/de handled 18 psi like a champ with a vj17/14 hybrid, with a fairly aggressive timing map (i only had the disty retarded 2*) and safe air fuel ratios
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
93' Rs-t BPT - Sold
Now the car is almost done.
another issue that worries me is when i have boost in closed loop situations.The ecu has an aggressive closed loop session,so i will defenately have a problem and i need an o2 clamp?
anyone? am on a rush.Tanner_gr wrote:Now the car is almost done.
- se7en
what is an o2 clamp?
7
7
thepurpleone
i have a 94 mazda mx3 rs with a b6de and it has about 142000 miles, i have a t25 turbo off an eclipse but, thats about all i have right now. i guess my question is, what all do i need to finish the rest of my dream (to turbo my mx3 rs)?
- se7en
well, you are going to need a wastegate, turbo manifold, wideband o2, better fuel pump, bigger injectors, intercooler, and piping, and a good EMS, and a few other small things.... good luck.
