I got a GARETT M20 turbo! How much do you guys think ill be
Juans_93_MX3
Post by Juans_93_MX3 »
Well I didnt buy it. I guess the last owner of my junkyard MX3 had it but for some reason left it in the car. Its the turbo itself witha wastegate.
Looks like it will need to be rebuilt
As some of you know, im changing to 5speed/KLZE
But, I found this in the back of the junkyard MX3
I cant really read the turbo. It sure says Garret. But it seems like it says M20? Never heard of a Garret M20...
Anyone have a idea what car this could of came from?
It looks like it is missing a part to it. I dont know much about turbos, except how they work. Dont know what its missing
2008 Mazda 3
1993 MX3 GS
Cy
Post by Cy »
garrett doesn't make an M20?...to mine and google's knowledge.??
pics?
Juans_93_MX3
EDIT: I think its a M20. Ill have to take another look tommorrow. Dosent Garrett only make T3 and T4 turbos? All I know is that I have a Garrett. I couldnt really read what it said. It was in bad shape
2008 Mazda 3
1993 MX3 GS
Custommx3
Site Administrator
Post by Custommx3 »
Moved to Forced Induction...
Juans_93_MX3
BUMP, its a update
2008 Mazda 3
1993 MX3 GS
fieromx3
Post by fieromx3 »
i doubt that turbo is big enuff for a high revving ZE.. if u ever get around to that..
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
nos92mx3
Post by nos92mx3 »
Email garrett and see what they say about it, there techs are normally very helpful.
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
rebel2k4
Post by rebel2k4 »
I can tell by looking, thats a T04B V or H trim. do you have a micrometer? if you measure the inducer and exducer you can determine the trim.
theres also no wastegate on that turbo. youd have to run an external.
the turbine housing looks very large, are there any a/r numbers stamped in it? looks 1.20 or larger. definitely a T4 frame turbo. I personally think it's too large. if its a P trim in the turbine housing as i suspect, likely wont get full boost until the top of 2nd gear with a KL. You could swap to a smaller turbine housing if you find out what trim the turbine wheel is. You can pick up a .58 for a reasonable price and then youd have yourself a fine turbo for 350-400 whp.
98 Ford Ranger 3.0L
fieromx3
Post by fieromx3 »
lol it looked small at first glance that compressor still seems small but that turbine is huge.. wonder what it came off of?
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
rebel2k4
Post by rebel2k4 »
some type of diesel. tractor or forklift perhaps?
that compressor is actually quite large. it has a 2.75" exducer and ~2.2" inducer. It can support 400 hp.
98 Ford Ranger 3.0L
Return to “Forced Induction”
