Well i finally got rid of that side mount saab intercoolere (that i mounted in the front) And got one of thems peeerrrty aluminum intercoolers that everyone has nowadays : P haha
Its slightly to big for me only running 9 psi...but oh well looks good.
Notice my lazy eye headlight....gotta fix that : P
old one
and i had to save a lil bit of the inside of the bumper...but i had already did that for my other intercooler...so it pretty much dropped right in. keep inmine i have no powersteering oil cooler..but i think it would fit with it there..maybe not.
The Psteering loop can be moved around...it's on hoses vs. pipe so that shouldn't be any issue...
posting here because the link will go dead
Length 29"
Length (Core) 22"
Height 8"
Height (Core) 8"
Thickness 3.5"
Inlet 2.5"
Outlet 2.5"
Compress Air Flow Rate <600Cubic Feet/Min, Rated to 400-500 Max HP
Working Pressure: 35~40PSI
Pressure Drop 2~5psi@35psi; 0.2~0.5psi@15psi
Hot Air Temperature 32癋~302癋 (0癈~150癈)
Material 100% Aluminum
Design Bar and Plate
Construction Machine Cut and Stamped, Hand Welded
Finish Polished
Net Weight 16 lbs
Works for
do you have any idea what kinda numbers your putting to the ground?
RED CAR: 94 MX-3 GS soon to be GS-R Engine: K8 weapon R intake, racing cat, pacesetter exhaust, 8.5 MM wires. Suspension and Breaks: Ground control coilovers, KYB GR2 struts, front and rear strut bars, crossdrilled rotors. Wheels and tires: ADV revolution 17" with Fuzion ZRI rubber. Body: Mazdaspeed front bumper, brand new paint job. Interior: X2 racing seats w/ 4 Pt harnesses, underglow under the dash, carbon fibre gauge bezel, reverse glow gauges, Painted trim Stereo: sony xplod head unit, pioneer 3 ways all around, rockford fosgate amp, lightning audio 1 farad capacitor, dual eclipse 12" subs. WHITE CAR: 93 MX-3 GS-R Engine: KL-ZE weapon R intake, SS autochrome headers, racing cat, 2.25 echaust with dual fartcan, curved neck intake and TB, intake and TB spacers, Stage 3 six puck clutch, 8.5 MM wires ordering fidanza flywheel this week. Suspension and Breaks: STOCK. Wheels and tires: STOCK with 225 bfgoodrich euro T/A rubber. Body: STOCK nasty and dirty car sat for four years before i brought it back to life, hood scoop. Interior: STRIPPED Stereo: Pioneer head unit, infinity 3 ways all around, rock ford fosgate amp, single 12" rockford punch sub
