How hard is it for you to put it in first?
- 94mx3precidia
as the title says, How hard is it for you guys to put it in first? All my other gears go in easy but say if im comming to a stop sign from 5th, put in the clutch, then put in into first really hard. I mean i have to kinda push hard on the shifter knob to get it in. There are no noises or grinding when i put it in, its just hard. I donno, its kinda hard to explain, let me know how it is for you guys. (94 GS 1.8L, 199000klm)
1994 MX-3 GS KLZE, Probinator, Bully stage 1 (probe GT), B&M Short Shifter, 2 1/4" Custom headders back.
- mr1in6billion
- 94mx3precidia
I normally don't ever downshift to first for this very reason... sometimes I'll shift from 5th to 3rd, then to 2nd. But I agree 1st is difficult to get into when rolling and it's always been like that. It's a little more difficult in my 626 tranny than the mx-3 tranny. This is only for downshifting though. If I am stopped going into first is no problem for either car.
![Image](http://i806.photobucket.com/albums/yy344/Mooneggz/laguna_seca_signature.jpg)
- 94mx3precidia
dont think of it as a problem, its more like a safety feature, if you could easily shift into 1st from 5th then BOOOM ![Smile :)](./images/smilies/icon_smile.gif)
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- 94mx3precidia
Yeah its a good thing but can be annoying some times in traffic.
1993 Mazda MX-3 GS, V6 KLZE 2.5L, CenterForce Duel Friction Clutch, Nylon Shifter Bushings (from Imazda.com), Integra Cold Air Intake, Millenia Intake Manifold, Indigo Gauges, Pacesetter Header->Resonator->2.5" piping->Dynomax Muffler, VSX Front and back bumpers from FX Designs, AWR Front and back Motor Mounts.
- babyblueMX3
I couldn't shift into first until I was stopped
RIP 400whp ZE-T MX-3
- 94mx3precidia
really? i can shift through all my gears if im crusing to a stop sign(with clutch in) the only one thats hard is first and a little bit for second. I dunno, this is my first standard car so it could be the same for all cars.
- XxantwawnxX
i have no prob shifting to first from any gear....not that i do it alot...
You can shift into first but only if you are going at a VERY low speed.. like 5 mph or less. If you try it faster than that, the transaxle grinds or wont let you. Safety feature. 1st is only there to start off from not to downshift to.
-hec
- 94mx3precidia
[quote="hgallegos915"]You can shift into first but only if you are going at a VERY low speed.. like 5 mph or less. If you try it faster than that, the transaxle grinds or wont let you. Safety feature. 1st is only there to start off from not to downshift to.[/quote]
i was talking about with the clutch in, i dont downshift to slow down. id like to keep my clutch goin for as long as it can.
