Turbo ZE Questions
Turbo ZE Questions
Hey all I am looking around and reading up on turbo's. I plan on getting a ZE and upgrading all internals as well as turbo this thing. I am looking for intense WHP. I plan on spending roughly $10 000 CA for everything hopefully. I am looking for some insight from those that know what they are doing.
<b> Internals </b>
What do I gotta upgrade?
<b> Turbo </B>
Best Idea for this?
I am really in the dark right now for knowledge so anyones assitance is greatly appreciated.
<b> Internals </b>
<b> Turbo </B>
Best Idea for this?
- cjthor
search search search. turbo ze has been gone over a few times. I did a quick search on turbo ZE and came up with a bunch of threads.
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
2RotorsNaDream
Red Rocket
- XxantwawnxX
im sure if he wanted to do another car he would not of made this thread.Red Rocket wrote:Buy an rx7, 8000 at tiger japan
If ur gonna rebuild it you could get a cheaper KLDE and and just get the flat top pistons. Although you wont have the better flowing heads.
If you plan on spending so much money on the build, including internal upgrading, do this:
*use your DE block--bore it at least .020 over to get some nice fresh cylinder walls
*use your DE crank--at least have it polished and possibly cut down if the journals are in bad shape
*buy KLZE heads--swap over DE springs, locks, retainers (or spend a grip on aftermarket goodies)
*buy KLZE cams--or use your DE exhaust cams and use ZE inake cams (or buy turbo cams from an aftermarket dealer)
*buy a KLZE IM--or use your DE, depends if you are running out of cash at this point
*buy a new oil pump--best choice is a genuine OEM Mazda
*buy Toga HP bearings--period
*buy either Millenia S connecting rods or the best of the best, the almighty Pauter rods
*look for either Wiseco or Diamond pistons (order to the compression ratio of your preference)
*unless you are a bad-a--, have a professional assemble the bottom end
*have bottom end blue-printed and balanced
*connect the top end to the bottom end via new headbolts and Mazda headgaskets
T61 powered KLZE
- ruthless_mx3
oh stop it! you're getting me excitedn2ogsze wrote:If you plan on spending so much money on the build, including internal upgrading, do this:
that sounds like fun
nice heads up w/ the toga bearings, I assume some have had issues w/ other brands?
93 MX3 GS SE KLZE -- RIP May 1, 2011
14.007 @ 98.46 1.991 60ft -- the only time she made it to the 1/4
92 MX3 GS aka Goldmember - I'm trying to keep the legend going and as always credit to Andy for starting the legend
sc61 currently @ 8 psi, wiseco 10:1 pistons, K1 rods, ported ze heads w/ kl31 cams
