Ugh, any ideas on this problem....?
My car is awesome but it has had this problem for awhile now and it's driving me crazy. Let's see...
-it idles rough and feels like it's going to die on me when it's below 1 rpm.
-when I'm turning a corner, I need to give my car gas otherwise it feels like it's going to die on me and SOMETIMES it actually does! Then I sit there for a few minutes and push my gas over and over and it starts right back up, a little rough, but then goes back to normal.
-it's like, if I tried to roll through a stop sign, it probably would die on me.
-it drives fine when I'm on the free way and going fast
ANY ideas? I'm a clueless girl here, please help :] I've heard it could be the O2 sensor?? I also have a small hole in my exhaust manifold, could that play any part?
- Tropical Emerald 1993
Search for 'idle problem', there are lots of posts about it. Here's one recent:
http://www.mx-3.com/phpbb2/viewtopic.ph ... ht=#406854
I have a 95 as well! Does it leak any antifreeze? Any leaks in the coolant system will have that effect on them. The other thing is the water tempurature sensor it has two or three wires and screws into the head. It's not the water sensor with one wire - that one is for the gauge. I had both of these problems and it acted just like yours. Hope you get it fixed. Let me know if this helps out!
wheres the small hole at on your mani? if you have the stock airfilter and rubber tubing you could have cracks in it which may cause a vacuum leak. does it happen before or after your car gets fully warmed up if so it could be a bad coolant sensor like lost said. good luck lots of info on this site
I haven't seen any coolant leaks. The problem happens more frequently before the car is fully warmed up. It still happens occasionally when the car is warm - it depends on how you drive it. My small hole is off the pipe that comes off the lower part of the manifold.Bumpysbro wrote:wheres the small hole at on your mani? if you have the stock airfilter and rubber tubing you could have cracks in it which may cause a vacuum leak. does it happen before or after your car gets fully warmed up if so it could be a bad coolant sensor like lost said. good luck lots of info on this site
- mitmaks
vacuum leak
I actually did have a problem with my intake hose. I did purchase a brand new entire intake hose assembly from the dealer. The old one was very hard and cracked in some places, the new one you can tell the rubber feels the way it should be.SuperK wrote:Vacuum leak! Maybe. Doesn't always have to surge. I say get one of those cheapy ebay cold air and put it on. Has those metal pipings, won't ahve to worry bout them rubber leaks anymore. and it sounds neat, too
If the hole in the exhaust is close to the o2 sensor - air can mix with the exhaust and mess up the o2 readings. But if this is the problem it should happen mostly when the engine is warm.
The fuel filter might have been clogged too - replace fuel filter and run some injector cleaner with the next few fillups.
It could also be as simple as TPS adjustment -
94 Mx-3 Precidia
