where to find a good klze turbo hot & piping
i have read lots of forums but has anyone found anyone reliable to a kit from?
I ended up buying a set for the Probe/Mx-6 and then modified them for the MX-3. Came out sweet too.
I also made my own set of intercooler piping for my MX-3, with a nice size front mount.
Pics:
Pics:
- mx3autozam
- hppwdn
is that the vaf on the turbo inlet?
Mnemonic
very clean, although i might think your the person who stole my se's front lip as i can see yours is purple
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- XxantwawnxX
yes it ishppwdn wrote:is that the vaf on the turbo inlet?
and DAMN that intercooler is huge...doubt ur pushing enough boost to warrent that monster : P
Well as of right now probably not..lol. But I am the new proud owner of Rebel2k's Built motor...so i am sure it will be used when i am boosting and putting down 400+ WHPXxantwawnxX wrote:yes it ishppwdn wrote:is that the vaf on the turbo inlet?
- XxantwawnxX
WOOOOOWEEEEEEE
man i remember when being boosted was speacial...now everyone and there uncle has a snail under the hood!!!
Last edited by XxantwawnxX on February 10th, 2007, 10:08 pm, edited 1 time in total.
Mnemonic
and as soon as you bring me my car i will be specialXxantwawnxX wrote:WOOOOOWEEEEEEE
man i remember when being boosted was speacial...now everyone and there unly has a snail under the hood!!!
- XxantwawnxX
muahhuahahah never!
- hppwdn
I was just wondering what impact, if any, the placement of the vaf would have on IAT readings. Since the IAT is in the vaf and air temp pre compressor will be different than air temp post intercooler. In some conditions the difference will be larger than others. The temp difference could cause the stock ECU to use different fuel/timing depending on the difference between ambient temp (what the vaf will read on this setup) and post IC temps.Slammed6 wrote:Yes it is.
I have read all about different setups, and i personally don't feel that its "smart" to pressurize the VAF, As it was never intended to be pressurized.
