top end=nothing there
koireland
Hey quick question, I recently was testing out the supposed 230 km/h top speed of my car, and I was dissapointed to only be able to hit 170 km/h. I recently changed my spark plugs and the old ones were like burnt around the bottom of the ceramic. Do you think it's some sort of ignition problem? That's what I was thinking because 1st-3rd all pull hard, but 4th and 5th pull really weak.
- XxantwawnxX
your car WILL NOT go 143 MPH (230k) sorr not possbile..my car has a KLZE and a turbo and i cant go 143...you know why?
In 5th gear im at redline at about 137 MPH(220k) and we dont have a 6th gear.
And sorry to say the regular stock k8 1.8 liter v6 will not reach 137.
BUT 170k (105 mph) is a tad bit low...you should be able to hit 115 -125 but it WILL take u all day...and u might wanna have the wind at ur back.
Downhill doesn't hurt either.
Seriously at that point you are approaching HP = Wind Resistance So head or tail winds will pretty much directly affect your top speed.. (that's why all speed records have to be done with two runs, fairly close together, one in each direction of the course)
You'll also start to feel anything like a dirty air filter, under inflated tires, tires with high rolling resistance, etc.
Still 105 is a bit low I'd agree.. how many miles on the engine? has it been compression tested recently? etc.
{sigh} Time to move on
Out with the old: Tropical Emerald MX-3 GSR (KL-DE)
In with the new: Phantom Blue Mazda3s GT
koireland
240,000km's and nope no compression test lately. Timing belt done 10,000km ago, Oil changed regularaly, new spark plugs, need's a new air filter but they didn't have any in stock, didn't thinkit would make a big impact, and maybe could use new spark plug wires. I was just concerned with the burnt look of the ceramic on the old plugs thinking it maybe was related. But regardless of top speed, it's super slow acceling from 140 km/h up.
- mx3autozam
- Ice Racing
Top end
I'm not a technician but that look that you're talking about might only be "rust overheating" from water into spark plug tube (coming from cleaning hi-pressure hose or overspray). I have a Kawa Concours and rain and overspray get in their and my sparkplug look like yours even after a short period of time but again i am not a tech and i have not seen your sparkplugs.http://i139.photobucket.com/albums/q295 ... 4c_800.jpg
P.S. I would have a compression test done before spending important amount of money fixing it...
GS KLZE FOR ICE RACING
- XxantwawnxX
ok it might do 143 mph (230) if u were going down a steep hill with a hurricane behind you.mx3autozam wrote:wel it is a k8 so after 140 it aint gunna move to quick.
umm to the oen guy who says it won't do 230km/h it sure will..i've done it and i know a few other who have!
NOrmall it will not. Unless maybe u changed trannys or gear ratios theres thothing to be said. OR ur rims or so off size its changing ur speed reading.
Cause i get up to 137-138 VERY very fast with power to spare and i cant go faster cause im at redline. Cant argue with gear ratio's no matter how much power u have.
137 is pretty close to 143...so im think rim size or sumthing similar has sumthingot do to ur readings.
hgallegos915
My ze can only go to 130 and it tops off well i dont wanna blow bearing number 6. Why do you want to go that fast?
-hec
- hppwdn
In my ZE MX3 all motor the speedometer tapped all the way over to 150 one day when I got a little too out of hand on the highway. That was all the way at redline in 5th. I had 205/40/17s on the car at the time which calculate to a 1.79% difference from stock. (According to this link http://www.1010tires.com/TireSizeCalcul ... ion=submit)
That calculates out to 147mph.
Turbo it gets to 140 in the blink of an eye on stock size tires. But I try not to go past 120 very often since I turbo'd it with the whole boosting in fifth gear is bad thing.
I still use the stock MX3 transmission so the gear ratios are stock.
If your car is making power it can pull well past 150mph, but with our stock gear ratios you won't get there. With an MX6 transmission redline in 5th gear will let you see about 166mph. I proved this on a dyno one day in my old probe. You'd just need enough power to get there.
Now if you were to build your engine and push up your redline you could go much faster on stock gear ratios. The PRM probe that runs 11s all motor gets somewhere beyond 120mph in 4th gear, but it revs out real high.
Here's a pic one day of when it was all motor a passenger snapped. That was another 140+ day. I took it to 140+ quite a bit when it was all motor. Going fast helped burn off stress from living in Miami and dealing with all the rush hour traffic.
- XxantwawnxX
In you your picture, thats jjust about to were i can get...i can never get past 140, id like see a pic of it past 140 before i change my statement
I could of always maybe not pushed it hardenough and could be very well wrong, guess i gotta find out one day again...although as i get older i tend not to want to go that fast anymore haha.
- XxantwawnxX
well for ont thing the stock motors are just not powerful, add ur dirty airfilter than that could be it. Me and hppwdn both are heavy modified.
