Thinking of buying a 4cyl MX3, what is the potential?
Juans_93_MX3
Post by Juans_93_MX3 »
As many of you know me, I own a V6 MX3 and am thinking of doing the 5speed swap aswell as KLZE with other mods
Anyway, lately I been finding 4cyl MX3s for cheap and I just got a couple questions
1.) A BPT should run me from $800 to $1200 and that includes the turbo and piping aswell as the turbo manifold?
2.) What is the fastest way to get atleast 240hp out of these BPTs?
Can you upgrade the turbo to like a T3/T4, 3inch downpipe/exhaust manifold/exhaust, bigger fuel injectors, boost control?
Seriously, is it hard to get these BPTs to 240hp without spend too much money?
2008 Mazda 3
1993 MX3 GS
Limegreen mx-3
Post by Limegreen mx-3 »
what ur $$$$ or $$$ really whats ur buget man. i have a quick 4cly mx-3
Juans_93_MX3
I can buy a RS for like $1000 and after I paint my MX3 GS I can sell it for $2200
I am willing to spend about $2000-$2500 on a MX3
BPT swap is about $1000, but is it a easy swap?
I can get a T3 for like $300. But would a T3 work well with a BPT?
I wouldnt mind spending more money on a intercooler.
Now tell me, is it easy to mod the BPTs like it is to like say a GST Eclipse or GSX Eclipse where all you really have to do is add a bigger exhaust, intercooler, boost control, dyno tune, bigger turbo and other small stuff to get to about 240hp?
In other words, a few mods here and there, dyno tuning and bam 240hp?
I'm just kind of hyped about the BPT because it does come with a turbo
2008 Mazda 3
1993 MX3 GS
Limegreen mx-3
well fist off i don't a BPT in my mx-3 i have the N/A BP second cost money man. iam running a SC61 on my bp i think like a honda guy more power but i drive a mazda. reason for that remark and i work at a shop. honda guys aren't afarid to spent money but mazda guys are cheap. hate to say that but its true. i begged my bother to upgrade to a street/race setup on his MX-6 GT.
94blaze1.6
Post by 94blaze1.6 »
you can prolly get close to 220hp without ugrading the turbo on the bpt.
95 RS so far just a paintjob, rims suspension next then turbo...
Image I have turbo dreams and detanation nightmares
Juans_93_MX3
How much does a BP cost (not a BPT)?
Can the internals take a good beating?
What would be a better option? Buying a BPT then changing the turbo or buying a BP and adding a turbo system?
Also, if I just want to hit 220hp, what mods would I go for?
Or how about this, if I just want to stick at 200hp and 160ft torque, other then changing the engine, water pump, timing belt and the other parts is there anything big I have to change that might cost me alot of money?
No need to change tranny or wiring harness?
Is it a simple swap?
2008 Mazda 3
1993 MX3 GS
94blaze1.6
the bp is can be had for cheap and it can take up to 25 psi on stock internals. If you are planning on upgrading the turbo on the bpt right away I would start off with the bp and buy the turbo mani for it that will be cheaper then buying a bpt and then ugrading the mani and the turbo. If you are not sure the bp can take some boost, talk to limegreen he's got a bp with stock internals and hes making 12 sec passes....
Juans_93_MX3
So how much do BPs cost and do I have to get them imported like BPTs and KLZEs?
Simple swap?
2008 Mazda 3
1993 MX3 GS
94blaze1.6
well they are easy to swap into pre94 mxs 94,95,95 are a pain to wire... You can get them locally no need to import, they came in 90-94 proteges and escorts...
Juans_93_MX3
Ok, so avoid pre 94 MX3s
2008 Mazda 3
1993 MX3 GS
TREVO123
Post by TREVO123 »
crank the boost
it's hard to decide, but if i'd ever do it again i'd be tempted to:
- 92-93 4Cyl
- BPT (maybe even Supercharge it? I like the N/A responce of the ZE)
- GS Steering rack
- GS Disk Brakes
- Possibly AWD (now that we know it's been done, I'd love too!) In that case, lowering it for racing or raise it for rally?
papa roached
Post by papa roached »
Juans_93_MX3 wrote:Ok, so avoid pre 94 MX3s
no avoid 94 and later RSs, the swap is easier on the 92 and 93
Limegreen mx-3
[quote="94blaze1.6"]25 psi on stock internals..[/quote] 25 psi, iam crazy i'll boost that bi tc h up up 30psi and see if it can handle it. i am not afraid to try crazy shyt i love boost and if it give's well them i'll get another replacement.. there are a few crazy mazda guy up in these joint.
Juans_93_MX3
I think I am going to go that route then
Seeing that these BP engine have alot more potential then the KLZEs
I think I can get away with spending $2000 on a turbo system for the BP engine. Everything from fuel mangment to the turbo itself
What is the best turbo for a BP?
2008 Mazda 3
1993 MX3 GS
