hi, just wanna no how to take the front fenders off,
n e one fitted lambos and wrere they hard, lots of modification required???
cheers
removal of front fenders for lambos
never did the lambo conversion but fenders are pretty simple to remove. bolts alnd the top of the fender whe the hood is up ( i think 4). Then open the door and inside like where the door hinges are there is one or 2 bolts ans then the last bolt on the very bottom of the fender sort've under the car. You will need to take a few screws out of the inner fender plastic too.
1993 GS
-MS front -functional molded hood scoop
-MS molded sides-shaved antenna
-Civic projectors -New black paintjob
- TREVO123
is it possible to install the doors without removing the fenders?cuz i have a molded kit, and dont wanna wreck it.
- TREVO123
ya everythin is molded.
i've got a universal kit > best available in the uk and it's going to be a real pain to fit. requires alot of work not an easy conversion to do right.
check my car domain
http://www.cardomain.com/ride/2144443
