Engine Swap
Engine Swap
It may be vague question, but roughly how much would the labor cost to have a mechanic do an engine swap for me? US
- BornSticky
one million dollars!!!!!!!!!!!
no really expect like 1-2 grand for gay labour do it yourself cause it is ez x100000000
so dont get gaytown mechanic to do it unless you r mentally retarded
and yes i probably got this thread deleted
#5389 to join MX-3.com
7h15 0n3 71m3 47 f0rum c4mp, 7h15 7hr34d 607 d3|373d.
w3rd pnwed...
-hec
- papa roached
BornSticky wrote:one million dollars!!!!!!!!!!!
- ryan_Fuerte
probably be around 1000 to go an engine swap in labour
Mx-3 GSr : Rebuilt klde with 5spd swap, xtd stage 3 clutch, Magnaflow dual exhaust,Accord custom intake, kyb gr2 struts with eibach springs, civic dual halo projectors, black altezzas, white 15'' oz rims, rolling on dunlop street slicks.
http://www.cardomain.com/ride/2400330
- 2fazed
Re: Engine Swap
First, you need to tell us what state you live in, so maybe we can answer you. Here in Cali, you can get a swap for $500. No warranty.superman_t11 wrote:It may be vague question, but roughly how much would the labor cost to have a mechanic do an engine swap for me? US
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
cost me $1000, and I helped.
It it all depends, there are many things you can do for the swap, and preventative maintenance while the motor is out, which wouldn't be a bad idea. Some people can do it in a day, other's a few evenings, depends on who and what. Talk to a mechanic, that's probably the best way to get an idea on price.
