I'm sure most have read my thread about my klze dieing on the highwayand not even cranking again. well today I took it apart to see what went wrong. After pulling the oil pan it was all in the bottom of the pan. I just pushed the piston out from the top. I have absolutly no clue what happened here. I also tried piecing the piston together and figured out there must be another piston thats screwed since I have part of it that says "kl31" yet the piswton I have has "kl31 on it. Its just beside the piston pin. Going to look tommoow and see if theres any other damaged pistons. And holy crap that rod is bent
Now I know why you were pulling the pulley off. Sorry for your luck.
Stacy Whitrick
MX-West Calgary http://www.cardomain.com/ride/1335558 UPDATED June 6,07
94 GS, Green Envy Pearl QUESTION: Does my car fit the RICE category?
JWMX3 wrote:thata boy johnny........ if its gonna blow, let it blow sky high
last thing you wanna do is tear apart an engine for some little b---- thing, bring on the carnage
lol..exactly
I am kinda mad that i have to buy a new motor and stuff but I feel kinda proud I grenaded a ZE. But I bought my ZE for $200 it was screwed..guy was an idiot and overheated it. I rebuilt it. rings and all. Itw as quick but never did feel right. Now is time to buy a good one from an importer and add some boost
Parts needing installed: turbo kit from BB (if i ever get it), 9.0:1 CR Diamond pistons, 4340 forged H beam rods, C/J-Spec spoiler, Nissan red tops in KL rails http://www.cardomain.com/id/blazejeremy
