The Aftermath
- mx3autozam
The Aftermath
I'm sure most have read my thread about my klze dieing on the highwayand not even cranking again. well today I took it apart to see what went wrong. After pulling the oil pan it was all in the bottom of the pan. I just pushed the piston out from the top. I have absolutly no clue what happened here. I also tried piecing the piston together and figured out there must be another piston thats screwed since I have part of it that says "kl31" yet the piswton I have has "kl31 on it. Its just beside the piston pin. Going to look tommoow and see if theres any other damaged pistons. And holy crap that rod is bent
93 Mazda MX3 KLZE Turbo
- mr1in6billion
- Bling Bling
Now I know why you were pulling the pulley off. Sorry for your luck.
Stacy Whitrick
MX-West Calgary
http://www.cardomain.com/ride/1335558 UPDATED June 6,07
94 GS, Green Envy Pearl QUESTION: Does my car fit the RICE category?
MX-West Calgary
- mx3autozam
lol..exactlyJWMX3 wrote:thata boy johnny........ if its gonna blow, let it blow sky high
last thing you wanna do is tear apart an engine for some little b---- thing, bring on the carnage
I am kinda mad that i have to buy a new motor and stuff but I feel kinda proud I grenaded a ZE. But I bought my ZE for $200 it was screwed..guy was an idiot and overheated it. I rebuilt it. rings and all. Itw as quick but never did feel right. Now is time to buy a good one from an importer and add some boost
That wasnt a dropped valve... was it?
-hec
- mx3autozam
lol...ya no really ehnos92mx3 wrote:meh some 5 minute epoxy or some jb weld will fix er right up
I know someone who cracked a tranny case and jb welded it back together and raced the car for another year on that.lol
Last edited by mx3autozam on November 28th, 2006, 3:26 am, edited 1 time in total.
- papa roached
itll buff out
- mitmaks
weld that up man
- jschrauwen
