Aftermarket Headlight Assembly
Can anyone point me to a good website or otherwise company that deals in aftermarket headlight assemblies for a '93 Mx-3? It's going to cost me $600 to replace my headlights if I can't find a good aftermarket retailer. Any help at all would be appreciated.<P>--Cory
Re: Aftermarket Headlight Assembly
as far as aftermarket headlights, all i can think of is the glass jdm headlights, which will run just about the same if not more. try calling junkyards and mazda recyling centers.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
If you want talk to SRD to find out the deal, but about 2 months ago I talked to them about projector headlights and they said they MIGHT start a project to make some. Don't know the deal now cause I told them I try them later to see what's up. [img]shrug.gif"%20border="0[/img]
no, actually do NOT talk to SRD. if they get bothered too much, they'll stop making them. they told me so through an email.<P>dave
wouldnt it be good if people were asking about them? it would meen theres a better market for em.
<A HREF="http://www.geocities.com/mail_cory_here" TARGET=_blank>Codenes Car</A>
- PATDIESEL
if you are replacing them because of the ugly film on the plastic lense i heard that you can heat the glue around the edge and then clean them. not sure about this though so don't try it unless you are ready to replce them if it does not work. if it doesn't then the glass ones i know you can clean when they get dirty. however, i would be extremely interested in projection headlights!
- PATDIESEL
shoot, about the earlier reply yopu heat the glue and then pull the lense off so that you can clean the inside. not sure though, might be that the plastic is just discolouring
Actually, a small buffer and some plastic polish will get rid of the yellow discoloration on the outside of the headlights. Just put in a little bit of time and they will shine up nice.<P><BR>-Kevin
George Jefferson= Reason for birth control
How do you heat the glue up? Do you use a heat gun or what?
94 Mazda MX-3 BPT Custom Intake/Exhaust T3/T4, 51mm BOV, Tial WG, 2.5" Piping, 880cc Inj, Godspeed Intercooler, TEC II
My MX-3 Website
My MX-3 Website
- David Witherow
you could but if you want to get an even distribution of heat so you dont warp them put them in the oven on a low heat setting and to put them back on do the same thing but wrap some string around them to hold the lens on while it heats up the sealant
I guess the same could be said for the taillights as well.
My MX-3 Website
My MX-3 Website
what you need to do is get plexiglass cleaner I had the same problem when I bought my car...I recomend FLITZ and a non toxic non corosive cleaner, and it dose wonders. I almost didnt by my MX-3 because the headlight covers where so incredably yellow. 2 minuates of rubbing this cleaner on it, and Wall-aaah looks as clean and clear as show floor Miata light covers!!!
