transmission shift stabalazer bolt
GreenMachine
Post by GreenMachine »
I think i addressed the topic right, the shift stabalizer that actually bolts to the transmission, but stays completley stationary. I just need to know what bolt goes to hold this on. in this diagram i have highlighted the piece i am talking about but it looks like a nut in the picture and there is not stud on the transmission that i can see to attach it to. Does anyone know the thread pitch in there? nut or bolt holding it on? Is it a specific bolt/nut or will any similar sized metric bolt work in there? any help is greatly appriciated.
sorry picture is so small
GreenMachine
scratch that, found out transmission case bolt is same size, screwed it in and it works :roll:
rebel2k4
Post by rebel2k4 »
Thats normally a stud.
But yeah theres a few thread patterns and sizes used for the whole car, so bolts can get moved around just fine. It makes things nice to not have a ton of different ones.
98 Ford Ranger 3.0L
