Water pump
- 1REVVIN3
Water pump
How much of a pain in the a-- is it to change a water pump in my k8?
- XxantwawnxX
The most annoying part for me was getting off the timing belt cover. After that it wass pretty striaght forward. The mount near the pump has to be taking off and u hold the motor up with a jack(least how i did it) And its pretty easy. Once i got the timing covers off it took about...an hour maybe...less.
