HEY ALL!!!
Does anyone know where i could perchase some clear indicator lenses?
or could i go to my local Halfords n buy em of the shelf
thanx
INDICATERS/SIDE REPEATERS
- Aiden Ulph
- Aiden Ulph
- Aiden Ulph
- garfy1981
mine are from a mazda 6, theres a small lip on the repeater that needs trimming and there is a bit of wiring to alter, but its pretty easy.
![Image](http://i26.photobucket.com/albums/c104/garfy1981/photo3.jpg)
2.5 Ze straight neck, blitz intake, mazdaspeed engine mounts, fidenza flywheel, CM II Clutch, KL-36 ecu, Magnecor 8mm Leads, Battery Relocation. Hotshot headers, 2.5 mandrel bent stainless exhaust, hi-flow cat, Speed hut dials, custom coilover set up. Custom willwood big brake conversion.
- Aiden Ulph
- garfy1981
no all you need are 4 of the small spade connection ( same size as the small terminal found on speakers) 4 male bullet lugs and 4 female bullet lugs. Push the small spade lugs onto the repeater connections then seal around the connections with silicone to stop them shorting out !!, then chop off the existing plug that went onto the orange repeater and use the male and female bullet connections to connect to the existing wiring.
the mazda 6 repeater will need about 2mm chopped off it, on the back your see and plastic retaining clip and on the opposite side your see a triangle shaped bit of plastic that holds onto the repeater to the wing. This needs about 2mm chopped off with a dremal but retaining the same shape. You should be able to see what i mean if you do get them.
I got them from mazda they wernt expensive. but i cant remember how much ???
just a note, before you start anything take off your orange indicator and check the condition of the paint underneath, onle of mine is a bit poor and needs alot of t-cutting to blend in with the rest of the wing.
- Aiden Ulph
