Emergency!!!
Flinch
Emergency!!!
Post by Flinch »
I am reswaping my ZE because of the broken cam and spun head bering, we got the new one in and mostly hooked up when we were tightening the belt for the powerstearing the tensioner broke. is there anyone in Calgary with a K8 that can spare the bracket with the tensioner for the power steering? Please Help! PM my name is Matt.
-KL31 stock internals with curved neck intake manifold and KL36 ecu
-Turbo running 7.5psi
-FMI 3"x12"x32" all alluminum and welded, have a 7.5 PSI spring she just creeps on cold nights
-ACT 6puck sprung/96 probe tranny
-Short shifter
-HEI and MSD 6al (makes a big difference when you spend the 65$ ont he right spark plugs)
-KYB GR-2 struts with H & R springs
-Megan racing seats
-Personal 280mm stearing wheel
-Familia rear strut tower bar
babyblueMX3
Post by babyblueMX3 »
well if you can wait a little I can sell you one and ship it asap.
RIP 400whp ZE-T MX-3
lakersfan1
Post by lakersfan1 »
How do you spin a 'head bearing' when our cams have no bearings? You mean a rod bearing?
babyblueMX3
he probably meant he scored a journal
Flinch
Post by Flinch »
How long and how much?
-Short shifter
-Megan racing seats
lakersfan1
babyblueMX3 wrote:he probably meant he scored a journal
That's not enough to junk heads IMO. I would have just got new cam set and called it a day.
noodlesphoenix
Post by noodlesphoenix »
it was the end cam bearing on the head side. it was scored severely and wore the cam down to the breaking point. the cost of getting the bearing caps cut and line bored would cost more than the motor. plus it was on warranty so the motor was replaced. now quit correcting his mistakes, if you have no reason to post, dont post, if you have the part, great let us know.
lakersfan1 wrote:How do you spin a 'head bearing' when our cams have no bearings? You mean a rod bearing?
there is bearings on the head, they just arent replacable, as its the actual head acting as the bearing material.
lakersfan1 wrote:That's not enough to junk heads IMO. I would have just got new cam set and called it a day.
you can have the old motor if you want. i'll put new cams in, see how long it lasts for you.
~BPT~
