v6 Engine Problem. Help!
last night i had driven home 5 minutes from the grocery store, when about to park, the engine began to shake and the car began to shake.
i had immediately parked and turned the car off. this morning i turned the car on and it began doing the same thing as last night. the Engine is "fluttering". when i put my foot on the throttle, it almost sounds like the exhaust is fluttering aswell. it is almost as though the exhaust or engine is misfiring. i have checked all oils and waters and have checked the spark plugs for excessive oil. the spark plugs are clean and dry. I then phoned a local mazda and had asked him questions, he can answer those for me for a "small fee" as he needs to book an appointment to look at it. Help please, very low on money and stumped.
the car is driveable yet i dont want to drive it in this condition thus making the problem bigger....
took my car to mazda today and he cant see any "extreme" damage yet he still doesnt know what is wrong with it. No check engine lights have come on, nothing major looks wrong. I have checked everything that there is to be checked and cant seem to come up with anything. Rather then getting more damage to the car by driving it, im just bummin rides off buddies until i can get this fixed. any ideas anyone?
- kiwi_MX3
- Location: Backpacking in Canada in vancouver 13march onwards
pull's on his stehoscope....
check your intake mainafolds " rubber accoridian" yup that ribbed
bit that bends around to the mainafold for cracks or leaks
thanks, everything looks good. i thought for a minute that maybe a o2 sensor was wrecked but if that was the case i would have a check engine light on which is not showing up. This is begginning to really piss me off as i cant figure out a way to do this without bringing my car to mazda and paying a fortune.
- XxantwawnxX
Maybe ur check engine light blew ? does it come on when ur first turn to the key to on?
Check the valve cover gaskets - usually that's the culprit for letting oil into the spark plug wells - its a relatively easier/cheaper repair (than a rebuild).
94 Mx-3 Precidia
