I've been searching for about 4 hours and can't find out wich ecu would best work with my mx3 with bp-t swap.
i wanted to use the aem ems but after talking with them, they said it wouldn't work, so that's left me with the
Apexi SAFC-2
Greddy eManage
Haltech e6k
or a corksport reprogrammed ecu
can anyone help me on this thanks
Best ECU to use with BP-T mx3
- atlantamx3
- MechaManZero
Corksport can find you one if your getting the gtx ecu. They are awsome cause the found me a gtr ECU in a matter of 3 weeks and those are rare.
Çlark
![Image](http://i64.photobucket.com/albums/h192/Mechamanzero/MX-3/2mx3.jpg)
95 Mazda MX3 4 Banger
Currently: H&R Lowering springs, BPT from a GTR, 18.5x6x3.5 same side inlet and outlet intercooler, Centerforce Dual Friction clutch
For BPT Frorums - http://www.aokforums.com/mazdaengines/
i have a bpt ecu but with a 94 mx3 it can be a pain in the a-- to wire. it runs pretty damn good but I still and have almost alwways had a jumpy idle when I have ac and brake lights on. It is not battery or alternator as both have been replaced and problem still remains. 94 mx3 just requires a lot of mixing of various ires from bpt harness and original mx3 harness. Fuel managemnt is good and I have a bpt vaf also.
