Stock Tyre Pressures?
matmobile
Post by matmobile »
Hi all, just purchased an Autozam AZ-3 and it rocks, but I don't have the manual... so I was wondering if someone could give me the correct tyre pressures... I'm running 30PSI all round atm, thanks much!
Grants
BANNED Member
Post by Grants »
Thats ok - 30psi is pretty good generally. It depends on the wheel / tyre package your running and what type of driving your doing but 30 is OK. If your on stockies, try 32.
Welcome to the forums!
mr1in6billion
Post by mr1in6billion »
It says on the sidewall of the tires.
Bochek
Post by Bochek »
mr1in6billion wrote:It says on the sidewall of the tires.
thats maximum pressure, not the correct pressure, check on the inside of your drivers door jam. theres a sticker there that says tire pressure.
Bochek
93-Spec-Edn
Post by 93-Spec-Edn »
its 32psi.
92 mx-3 RS RIP | 95 mx-3 GS sold | 93 mx-3 GS SE sold | 95 mx-3 GS present
lakersfan1
Post by lakersfan1 »
You need a kick in the nads.
Open your drivers door and look at the stickers. One of them tells you the correct pressure for the car. Every single car sold for the last 20 years should have the tire pressure sticker in the door jam unless it was repainted.
lakersfan1
93-Spec-Edn wrote:its 32psi.
On my door sticker, it says 28PSI on all corners. :shrug:
93-Spec-Edn
sorry i am talking about the 92-93 rs. not sure on teh GS, although I keep mine at 32psi.
matmobile
Post by matmobile »
Guys, I'm not that retarded! There is no sticker, perhaps it was removed, but any stuff at all on the car is in japanese anyway, and there are no numbers to be found!
I'll stick with 30PSI thanks much!
ho bag
Post by ho bag »
I tend to over inflate mine compare to the stock suggestion, but i stay under the maxium of the tire. Higher tire preasure will help increase gas millage.
2002 Mazda Protege5 (Turbo kit 75% complete)
1996 Mazda MX-3 Gs KL-ZE
1994 Mazda MX-3 Rs (BP-T?)
JWMX3
Post by JWMX3 »
remember to check your spare tire pressure and inflate to 60psi :lol: :roll:
my front tires go flat every 12 hours... i wonder if they leak ? :P
