Stock Tyre Pressures?
Hi all, just purchased an Autozam AZ-3 and it rocks, but I don't have the manual... so I was wondering if someone could give me the correct tyre pressures... I'm running 30PSI all round atm, thanks much!
- mr1in6billion
thats maximum pressure, not the correct pressure, check on the inside of your drivers door jam. theres a sticker there that says tire pressure.mr1in6billion wrote:It says on the sidewall of the tires.
Bochek
Adam Bochek's 93 1.6L SOHC http://www.bochek.ca/car.gif
- 93-Spec-Edn
You need a kick in the nads.mr1in6billion wrote:It says on the sidewall of the tires.
Open your drivers door and look at the stickers. One of them tells you the correct pressure for the car. Every single car sold for the last 20 years should have the tire pressure sticker in the door jam unless it was repainted.
- 93-Spec-Edn
