Junkyard Superchargers
Bochek
Post by Bochek »
Anyone know what cars i could get a supercharger off that would be found in a junkyard, and would be applicable (with fabrication obvisouly) to my B6?
Bochek
Limegreen mx-3
Post by Limegreen mx-3 »
don't go the cheap way.
Bochek
Post by Bochek »
reason being, im not trying to be totally cheep, im just looking for a good value SC, i can do all my own custom fab no prob, just need the actual unit.
Bochek
mr1in6billion
Post by mr1in6billion »
Jackson racing uses a M45 for their kit. Remaned M45s go for around 400. Found one on ebay for 425. Sport Car Compact used the JRSC in their project miata a while back, but eventually upgraded to an M62 (with modifications to make it fit). The MX should have enough room to fit it easily.
I was looking into SC's last night and found that sticking the SC in is quite a task. Some fancy work has to be done with the Power Steering since the pipes are located right above the belt. Once I have a good deal of money i'll probly just call jackson up and talk to them about it since they already have everything figured out.
I suggest you look at their pdf files to get some idea into what kind of fabrication needs to be done. Might be helpful.
G'luck. I hope your succesful (cause then I have a good idea of what i'm getting into :wink: ).
Return to “Forced Induction”
