Does the oil feed for the turbo have to be directly on the top of the turbo?? I have mine on top but slightly turned towards the block(maybe 1 inch from directly on top)??
Will this cause anything??
turbo oil feed position?
- Limegreen mx-3
do it like this oill feed on top oil return on bottom (oil return is the blue tube in pic.) u put ur oil return on top u'll have problems.
rockykarlos
- XxantwawnxX
Since the oil tap is so low on th epan he means not to over fill your oil. But i think that tap is fine, sure it could of been higher, but fine. Since the return line is using gravity to take the oil away u wouldlike it as high as possible so the oil in the pan is not covering the drain tap already.
XxantwawnxX wrote:Since the oil tap is so low on th epan he means not to over fill your oil. But i think that tap is fine, sure it could of been higher, but fine. Since the return line is using gravity to take the oil away u wouldlike it as high as possible so the oil in the pan is not covering the drain tap already.
^^ thats what i meant, if u block the oil return it builds pressure and will cause ur seals to blow
