Headunit Issues
93_4Banger
Headunit Issues
Ive just installed my stereo and the speakers are on but the head unit doesn't seem to be getting power. What do you think it could be?
The wires on the new stereo should be labelled. The wire colours for the existing wires are here:
http://eunos30x.com/info/Radio%20Circuit.pdf
You should be able to just use them ok.
It could be the ground too - thats pretty common. Make sure the ground from the stereo goes to a good ground point.
reaper of souls
93_4Banger
96 X-90 4x4, 16v custom ram air intake lockers front and rear with 5.83 ring and pinion.
