walbro 255 lph hp fule pump info
- claude matte
hi guys im kind of stuck what fuel pump should i get i was thinking walbro 255 lph hp fule pump is this only a in line pump and ndo i remove the stock pump or run both thank you for answering my dumb q
later
later
http://members.cardomain.com/mx3mazda
http://www.cardomain.com/ride/3346603" onclick="window.open(this.href);return false; new pics
- claude matte
thanks guys all i seem to find was the in line ver ,i thought i was on a witch hunt thanks
as far as a need i aim in tne process of turboing the car and am useing the megasqurit to control the fule dose anyone know where i can get my hands on some 550 nissan injectors ..
or is there a plug and play 550 that will fit our fule rail thanks again
- slimmyslim1420
You should be able to get the injectors at a junkyard. I recently bought a set in the rails with the connectors from a company on ebay that sells, fuel rails and etc. I only paid a little over $100 shipped for the whole thing, so it wasn't that bad. If you want to use them let me know and i'll get you their e-mail.
1992 GS ZE swap 94 dash swap drilled and slotted rotors full ceramic pads CS SS clutch and brake lines KL-36 ecu zx-2 tokico struts eibach springs short shifter Tenzo exhaust Hi flow cat 2.5 in piping
- claude matte
yes please im going mad trying to find a set it like 410 for a new set thanks
- slimmyslim1420
Here is their e-mail ebay@everyautoneed.com . Just write them and ask for some injectors/rails or whatever you need from one of the cars on the list babyblue put on the write up. They should be able to help.
- babyblueMX3
pretty much all nissan injectors (side feed) once modded will give 550cc. though they might have slight variation between the 6 injectors if you don't get them from the same car.
RIP 400whp ZE-T MX-3
- claude matte
thanks guys ill give them a try
- claude matte
injectors out of a Nissan Frontier/Exterra 3.3 V6 Fuel Rail With InJectors
i found but no engine code so i dont know if there right
- slimmyslim1420
Where did you find those. All you have to do is e-mail them with exactly what you need and they will let you know if they have it. I got mine from a doch 3.0 Maxima. you can use like 92-95 and 95-98 or something like that.
- claude matte
thank you slimmyslim1420
i did just that but i found the other ones on ebay before they got back to me . but all is good he has a set and there on there way so big thanks for the link and the help all is good got the intank and the injectors comming
JWMotorsports
Thought you might like to see the specs both the 255lph and 255lph High Pressure pums.
http://www.vfaq.com/mods/Walbro-specs.html
Typically a 255 HP can support around 500HP
- claude matte
nice chart thats what inline preformance said in his emails
but its nice to hear it from somone else thanks
