1st time noob questions
I own a 93 protege that I'm about to drop a mx3 V-6 in. I was wanting some info on the klze. as far as maintanance is conserned, can i use everything from the mx6 V-6 engine(timing belt,water pump,distributor,ect.). what parts are not interchangable. any info or links would help me greatly.thanks.
93 Protege lx,familia garnish,act clutch,port match intake/exaust manifolds,b&m short shifter,mx3 seats,rear lower tie bar and rear console, header,2 1/4 in exaust,catco high flow cat,rx7 mafs, cone filter,toga high volume oil pump,sr struts,b&g springs,zx2 hyper flex kit, 16in ssw wheels,Soon to be v6 powered
Yes, I will own a KLZE protege within the next 2 years. ZOOM ZOOM
Wait, why would you want a MX3 V6 engine?
Our stock engines are not KLZEs or even KLDEs
Their K8s
![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
Their K8s
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
he did mention klze but isnt it better to drop a bpt?
-hec
I'm dropping the k8 in there as a mock up. I will run that until i can get the KLZE.
thought about that. but i want something different.hgallegos915 wrote:he did mention klze but isnt it better to drop a bpt?
- relisys_3200
did you even read what he said?93_mx3_gs wrote:The K8 is not worth the money it costs to buy or the material its made of.
Its going to cost him an extra $100 maybe for the k8......then he has the platform for the zeprotegetuner wrote:I'm dropping the k8 in there as a mock up. I will run that until i can get the KLZE.
Brandon
1992 MX-3 GS-ZE
![Image](http://img.photobucket.com/albums/v635/relisys_3200/afterwash1a-1.jpg)
1992 MX-3 GS-ZE
- kiwi_MX3
- Location: Backpacking in Canada in vancouver 13march onwards
Ok.
The protege, is the same as the familia im using here, as long as yours
is a BG chassis, if its a BF your screwed.
You will need the mx3 lower front subframe as this bolts straight to
mount the KLZE or K8.
Depending on what loom is in the protege, you might want a complete
loom from a mx3 if your not wanting to run a aftermarket ECU
though on a personal note a aftermarket ECU is worth it PERIOD!
A probe gearbox or a mannual KLZE gearbox is a desired item as it
hasa taller final drive else gather a few "G" serise boxes up and make
what you want up.
Depending on what you want to do IE dragrace, you need to do a
HELL of a lot of work to stop parts breaking when you start making a
lot of HP!
what you want up.
lot of HP!
thanks for the info.I'm getting a mx3 v6 whole car and will be sitting both cars side by side.I belong to clubprotege.com and there are a few people on there that have done this swap. so I know that the engine will go in there with no problem(except rad. fan). this car will be a daily driver.I would have done the bpt swap but i want reliability without breaking the bank.plus i like the tone of the mx6 engine. my question for everyone was about maintaining the klze. regular maitinance like timing belts,distributor car,rotor,plugs,oil filter,water pump,oil pump,basicaly i want to know what parts i would have to order for the klze that i couldnt order from a mx6 v6.whats not interchangable.kiwi_MX3 wrote:Ok.
what you want up.
lot of HP!
or should i just get a mx6 or probe parts car. and get the things off the mx3 from a junk yard.
None. Every single solitary part that might break on a KLZE is a direct swap with KLDE parts. Every single bolt hole on the KLZE is the same as a KLDE is the same as a K8. Timing crap, cams, head bolts ...... ALLLLLLLLLLLLLLL swappable.protegetuner wrote:what parts i would have to order for the klze that i couldnt order from a mx6 v6.whats not interchangable.
thank you. thats exacly what i needed to knowlakersfan1 wrote:None. Every single solitary part that might break on a KLZE is a direct swap with KLDE parts. Every single bolt hole on the KLZE is the same as a KLDE is the same as a K8. Timing crap, cams, head bolts ...... ALLLLLLLLLLLLLLL swappable.protegetuner wrote:what parts i would have to order for the klze that i couldnt order from a mx6 v6.whats not interchangable.
in that case why get a k8, get a kfze they are all over the net being passed as kldes :/ i mean yeah you are doing it as a mock up but its not realy anything different you are doing because at the end it will be exactly as a gs ... even if you drop a klze its not really anything different from what any of us have done...
-hec
i saw the kfze. is it the same setup as the k8.only its rated 170hp. if thats the case i will drop that in instead and be happy untill i can upgrade. will the millinium intake mani and heads fit on that.hgallegos915 wrote:in that case why get a k8, get a kfze they are all over the net being passed as kldes :/ i mean yeah you are doing it as a mock up but its not realy anything different you are doing because at the end it will be exactly as a gs ... even if you drop a klze its not really anything different from what any of us have done...
