turn down boost with boost controler??
Joey's mx
Post by Joey's mx »
I have read somewhere that you cant turn down the boost with a manual boost controler with an internal wastegate, is this true?? It said that you can only turn up the boost and the watsegate will only open to what it is set for not any sooner??
Is there anyway to turn down the boost with an internal wastegate??
Franko
Post by Franko »
The base boost level is detrimined by the spring in the wastegate. I dont think that you can make it open sooner since you need pressure to activate the wastegate.
Why? What is the boost level at now?
osargeant
Post by osargeant »
You can only turn up the boost with a manual boost controller not down. You would have to fiddle with the wastegate rod to get boost lower than whatever the stock setting is.
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
Return to “Forced Induction”
