Does the ZE and DE have the same bottom end?
- XxantwawnxX
As in same strenth and everything? Except for thje higher compression pistons of course.
Yup either will bend rods about ~ 350 whp.
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
- XxantwawnxX
Thank ya : )
