shaky
shaky
I have a issue i'm not sure what the Problem or solution is any help is great. Well When i'm at a red light and waiting in "D" my car idles fine for a minute then shakes for a few seconds then back to normal then shakes again. I'm not sure what this is.. It seems like the engine is missing or something. Thanx for the help
- SnoSurferr
- azazel95
Check the fluid and the mounts. Could also possibly be your throttle body or IAC messed up. I'm not sure that an auto would act the same way but on my 5 speed, the idle would be fine in neutral but if I had it in gear the rpms would drop almost to the point of stalling. You might also want to check your vacuum hoses since your idle is going up and down.
Again, these are things I did for my 5 speed, so I don't know if an auto would be the same.
