Hi ! I am new to Mx-3.com, but I know this site for more than 5 years. Just because my last computer wasn't enough powerful to surf on the net ! My name is Ralph, and I'm from Québec, Canada.
So here is my project, a 1994 Mx-3 GS that I bought in 2000 @ 110 000km (now @ 160 000km).
See http://www.cardomain.com/id/silveracer for more (new pics on the way (clear corners, BSA 210 17 inches wheels ..)
Coming: H&R Sport springs, Koni adjustable inserts
In approx. one year: Fully build Hybrid KL 2.5L V6 (Secret recipe !), MazdaSpeed 225mm clutch kit (For J-Spec Mx-6 V6), Polyeurethane filled engine mounts, Fidanza 2.72Kg (9lbs) flywheel, Quaife ATB LSD, SRD Control arm bushings, CS Strut bars, Whiteline 22mm rear swaybar and more ! Stay tuned for a clean Mx-3 V6 !
Engine (K8 )
-Mobil1 10w30 Synthetic Oil w/Mazda filter
-Redline WatterWetter, 30% (V/V) Coolant / De-ionized Water ratio
-PRC Solenoid Modification
-"Mazdaspeed MS" Filler & Oil caps
-G25M-R Manual 5sp transmission, Motul Gear 300 75w90 synthetic Oil
Brake setup (More infos in ''Worklogs'' section)
''Interior''
-Pacesetter Short Throw adjustable Shifter w/SRD Nylatron extension rod bushing & Bronzoil shifter busings
-SRD Performance E-Brake Handle
-Vibrant Leather E-Brake Boot
-Alpena Pedal set
-APC Shift Knob
-Speedhut White gauges (Km/h, V6 Redline)
-A-Pillars and door handles have been color matched with the same code as the body of the car (Mazda "3L" Code, and then cleared
PaceSetter Short-Throw (adjustable) shifter
A-pillars:
Door handles rear ''covers'':
Greetings !
JM1EC-V6 - 1994 Mx-3 V6
- JM1EC-V6
'94 Mx-3 GS-R SE, KL-ZE Interprep. (From '96 PGT KL)
1110Kg
-Interprep KL31 Spec.
ported heads, Polished combustion chamber,3 angle vlv job,10.3:1 C.R.,0.020'' O.S.,KL31 cam,-0.007'' heads,Long neck IM,KL31 TB, Hotshot headers,2.25'' exhaust,Magnaflow cat
1110Kg
- Meep
Re: JM1EC-V6 - 1994 Mx-3 V6
Says you're 16. So you bought this car when you were 11?JM1EC-V6 wrote:a 1994 Mx-3 GS that I bought in 2000 !
- PATDIESEL
Must have bought it when he was 11 if he has done all that work and is only 16. LOL
Great job though, looks great and I love the alternate 5 spoke Mazda wheels. You hardly ever see them.
- mitmaks
clean ride
I think clean may be an understatement. WOW, you make even clean cars look dirty. Nice job
- JM1EC-V6
In fact, my mother bought it in 2000, when I was 11. Since she bought it, I just did the maintenance and started the project (little modifications ..) thus starting getting the money to buy it in the future, thing that I did last fall.Says you're 16. So you bought this car when you were 11?
Thanks for the comments !
1110Kg
1110Kg
