Engine Power Problems
- Black4CylMX3
i drive a 94 4 Cyl mx3 and it seems like whenever i turn on my air conditioning, my engine loses a ton of power, like to the point of when i start to drive from a complete stop its hard to go without almost stalling or my car will barely accelerate at all. And even if i turn it off my car will start acting up for a while, for instance the throttle will feel really loose, along with some other things. Has anyone else had this problem?
- tw1st3d_cl0wn
- Tunes67
Power loss with A/C use is normal.. however.. stalling out (or almost stalling) is probably an indicator that you need to clean your throttle body & reset your idle and/or run some fuel injector cleaner through your next couple of tanks of gas. Hope this helps
Tunes67
Tunes67
"So long.. and thanks for all the fish!" "Momma says VW Bugs are the devil" "This one time at band camp.. I stuck a flute in my Throttle Body" ![Wink ;)](./images/smilies/icon_wink.gif)
Darcy i don't think that there is a such thing as a 105 hp 1.6 for a mx3...atleast what was shipped to the U.S. mine is a 1.6 DOHC and i am running only 88....all ive seen was the 88 horse 1.6 and the 130 1.8
- Tunes67
Darcy is correct. 94+ Year RS MX-3's recieved a DOHC 1.6 that puts out 105 BHP. 92-93 model years had the SOHC 1.6 which only put out 88 BHP.
Tunes67
Tunes67
