new update on my car...
I put some new pics on my page if ya all want to cheak it out...
http://www.cardomain.com/id/mx392
1992 MX-3 GS in work.
2006 speed6, Wife say's i can't work on it.
2004 GSX-R 1000 Mat Mladin Replica
2006 toyota tacoma
1995 MX-6 in pieces almost ready for the junk yard, To much body damage.
2006 toyota tacoma
- PATDIESEL
Super clean exterior, love that silver color. The inside looks good too. I would eat off of your engine.
No seriously, I would...
- neverenuff
Yea, nice job.
Just one question. Maybe, I'm stupid (it has been suggested
) but, is it really an analog tach if you have a digital readout of your RPMs? I thought our OEM tach was analog, but you went to digital. Idunno.
I love it though, does it work flawlessly? I think you should put shifter paddles in next, seems to work well. cost some $$$ to do tho. Nice to dream.
MX-3 Owners Club of Atlanta
Clemson Sports Car Club #72
MOCA tuned straight-neck KL-ZE '93 MX-3 GS : Updated: 03/05/06
- mitmaks
looks clean
the tach works perfect. The next thing I am going to do is put in the speedometer that matches the tach. I am going to install it infront of the old speedo so I don't get into trouble. I am just going to add a tube that is going to pop out slightly so I can mount it. It is only a quarter of an inch thick so it will be easy. Well I thank you for all your posts I am going to be customizing alot now that I am at home for a liitle while... ![Very Happy :D](./images/smilies/icon_biggrin.gif)
2006 toyota tacoma
2006 toyota tacoma
- XxantwawnxX
Thats a digital tach you put in...not analog. unless im wrong. Nice car.
You mean those green bars from 7 to 1 o'clock are analog? That those green bars act linear to the revs/RPMs as-well-as you have a digital display (The centered numbers)?1992mx3 wrote:it is analog, with a digital extra. The guage its self is analog based.
That's the impression I got. But, if anything I'd say, "it's digital, with an analog extra." I guess I'm just missing what exact is making this thing analog.
Doesnt really matter, just mindless chatter
Naively,
~CHANKO
Im Very impressed with your tach. Where did you get that?
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
as far as keeping my engine bay cleand I use "simple green" and a hose wash it off. the tach and the speedomoter I got from my dad a long time ago witch were supposed to go into my camaro but I blew the engine in that. The packages that they came in said they were analog/digital guages, just like that so. I have tryed to find more of that style but they seem to be nonexistant. I also have a volt meter, and two pressure meters of the same style that I want to try and put in once I get the DE and turbo in...
2006 toyota tacoma
2006 toyota tacoma
I found the guages on http://www.summitracing.com1992mx3 wrote:as far as keeping my engine bay cleand I use "simple green" and a hose wash it off. the tach and the speedomoter I got from my dad a long time ago witch were supposed to go into my camaro but I blew the engine in that. The packages that they came in said they were analog/digital guages, just like that so. I have tryed to find more of that style but they seem to be nonexistant. I also have a volt meter, and two pressure meters of the same style that I want to try and put in once I get the DE and turbo in...
Holy cow man, you just dont know how long I have looked (not hard enough obviously) for those guages to prove to my pop's that they still make them and also to replace the ones that I accidently left in my camaro like the oil temp, egt (exhause gas temp) and the tranny temp.. Wow man thanks. by the way talon_66, NICE MX-3, very clean.
2006 toyota tacoma
2006 toyota tacoma
No problem. And Thanks.1992mx3 wrote:Holy cow man, you just dont know how long I have looked (not hard enough obviously) for those guages to prove to my pop's that they still make them and also to replace the ones that I accidently left in my camaro like the oil temp, egt (exhause gas temp) and the tranny temp.. Wow man thanks. by the way talon_66, NICE MX-3, very clean.
