the previous owner of my car had the strut replaced cause his blew out.
the car has been doin this for a while now. when i turn the wheel all the way to the right and back to the left. theres a popping noise. i thought maybe it was a borken cv shaft or tie rod. any way i had my friend turn the wheel while i watched it. and when he turned it back to the left. the spring like popped back into place or something. why does it do this? is it to tight? if so can i fix it?
spring to tight?
spring to tight?
95 Eagle Talon Tsi - New Toy
92 Mazda MX-3 RS - probably selling
86 Mazda Rx-7 - motor blew going 145
86 1/2 Toyota Supra - pissed me off sold it
91 Taurus... SHO - died
- freyguy_412
Are they upgraded springs? It sounds like maybe it's not sitting right on the strut. Try poppin it off and checkin to see if the bottom of the spring fits into the groove on the strut, you will see what I mean when you take it off. But I wouldn't reccomend doing this unless you are familiar with your suspension and have worked on it before. If you miss one bolt when puttin it back together, it could be nasty on the freeway.
It might be slow, but it's not a civic!
TsiMiata
That sounds exactly like the upper strut bearing is gone. They are relatively cheap to replace. Parts might run $20-$30 and if you've ever swapped out springs it's the same procedure as that to replace it.
91 Eagle Talon Tsi AWD *RIP*
