Help...need answer
Help...need answer
Did probes ever come with a 3.0 engine or an engine called a Vulcan?? Vulcan 3.0 came in Taurus / Sables. This guy is telling me they did, and saying he saw two of them in the Junkyard. I wanted to ask you all first before I told him he is Full of s---.
Check out the post here:
http://www.fastcougar.com/forums/messag ... did=118788
Thanks for the info.
I think he is pulling your chain.
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
yah the vulcan engine was the engine i think that came in SHOs taurus
(i think).
They didnt come stock in any probes EVER!!
HOWEVER, some people have swapped the SHO engines into probes and other vehicles for their potential.
(i think).
- Tunes67
I did a google search and came up with this :
Detailed Feature Information
2004 Ford Taurus
SE 4 Dr Wagon
Vulcan 3.0L 6 Cylinder 155 hp Gas Engine
Specifications
Type Gas
Number of Cylinders 6
Cylinder Configuration Vee
Number of Valves 12
Displacement 3.0L (3,000 cc)
Fuel Capacity 18 Gallons
Compression Ratio 9.70:1
Camshaft Configuration Center of Vee
Horsepower 155 @ 4900 rpm
Torque 185 @ 3950 rpm
Fuel Delivery Name Sequential Port Fuel Injection
Bore x Stroke 3.50 x 3.10
Hope this helps.
Tunes67
2004 Ford Taurus
SE 4 Dr Wagon
Specifications
Type Gas
Number of Valves 12
Hope this helps.
Tunes67
- relisys_3200
i found a site that said in 1990, the probe LX was given the Vulcan 3.0 liter 12-valve V6 engine with electronic fuel injection...
http://www.performanceprobe.com/text/info/history.htm
ive never heard of a 3ltr probe.... i guess ill retract my statements
