Help...need answer
RodbeyBur
Help...need answer
Post by RodbeyBur »
Did probes ever come with a 3.0 engine or an engine called a Vulcan?? Vulcan 3.0 came in Taurus / Sables. This guy is telling me they did, and saying he saw two of them in the Junkyard. I wanted to ask you all first before I told him he is Full of s---.
Check out the post here:
http://www.fastcougar.com/forums/messag ... did=118788
Thanks for the info.
Talon_66
Post by Talon_66 »
I think he is pulling your chain.
93 GS, KLZE, KL31 ECU, Centerforce Stg 3 Clutch, 2.25" Exhaust w/Flowmaster muffler, OBX Headers, Pheno Spacers, Front & rear X-drilled/slotted Rotors, KVR pads, SS brake & clutch lines, Ractive Filter, H&R Springs, Tokico Blue Struts, 8mm Accel Wires, MSD 6A w/ Blaster 2 Coil, HVAC Indiglo Panel. *Sold*
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
DavidOS
Post by DavidOS »
yah the vulcan engine was the engine i think that came in SHOs taurus
(i think).
They didnt come stock in any probes EVER!!
HOWEVER, some people have swapped the SHO engines into probes and other vehicles for their potential.
Tunes67
Post by Tunes67 »
I did a google search and came up with this :
Detailed Feature Information
2004 Ford Taurus
SE 4 Dr Wagon
Vulcan 3.0L 6 Cylinder 155 hp Gas Engine
Specifications
Type Gas
Number of Cylinders 6
Cylinder Configuration Vee
Number of Valves 12
Displacement 3.0L (3,000 cc)
Fuel Capacity 18 Gallons
Compression Ratio 9.70:1
Camshaft Configuration Center of Vee
Horsepower 155 @ 4900 rpm
Torque 185 @ 3950 rpm
Fuel Delivery Name Sequential Port Fuel Injection
Bore x Stroke 3.50 x 3.10
Hope this helps.
Tunes67
mxmaz
Post by mxmaz »
dont have a clue what the engine is called but the pre-93 probe had a 3.0L v6 option.
relisys_3200
Post by relisys_3200 »
i found a site that said in 1990, the probe LX was given the Vulcan 3.0 liter 12-valve V6 engine with electronic fuel injection...
http://www.performanceprobe.com/text/info/history.htm
DavidOS
Post by DavidOS »
ive never heard of a 3ltr probe.... i guess ill retract my statements
lakersfan1
Post by lakersfan1 »
The 89-92 Probe could be had with a 4 banger, turbo 4 banger, and a V6. The turbo was the fun car and the V6 was more a touring coupe.
Tunes67
Post by Tunes67 »
OOps.. sorry.. I misread the question.. Apparently they were available in the 1990 Probe.
Tunes67
RodbeyBur
Post by RodbeyBur »
Yea...i found the V-6 3.0 info a little late too. Stuck my foot in my mouth. LMAO.
SE-Man
Post by SE-Man »
Its a POS Ford engine, Ford didn't make good 6cylinder engines untill recently. They've alway's made good 8s though.... *cough* BOSS *cough*
