lightweight lug nuts
papa roached
Post by papa roached »
already got light weight wheels coming, konig heliums, what light weight lugs do you guys recomend?
mitmaks
Post by mitmaks »
I dont think there's any, they wouldnt play major role anyways, lol
babyblueMX3
Post by babyblueMX3 »
dude you'll be saving around 1lbs or less..what's the point.
go with standard
RIP 400whp ZE-T MX-3
papa roached
*looks at bronze wheels and chrome mis matched lugs on car* the only lugs i can get that will be black or bronze tend to be tuner lugs, and i was just asking since im gonna replace them anyway, thanx for the not help guys
Shady469
Post by Shady469 »
http://www.importstreetscenes.com/suspe ... /kyokugen/
i think they are cheaper from corksport though. and since they are open ended they should be approved by the sanctioned racing bodies...
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
TsiMiata
Post by TsiMiata »
I bought the kyokugen from corksport. They were an absolute waste of money. The tool that came with the set to take the lugs off stripped almost instantly. I had to take half the lug nuts off with a craftsman stripped bolt tool. I ened up with a bunch of ruined lug nuts and no way to take them off and on.
91 Eagle Talon Tsi AWD *RIP*
Steeb
Post by Steeb »
TsiMiata wrote:I bought the kyokugen from corksport. They were an absolute waste of money. The tool that came with the set to take the lugs off stripped almost instantly. I had to take half the lug nuts off with a craftsman stripped bolt tool. I ened up with a bunch of ruined lug nuts and no way to take them off and on.
kyokugen lug nut key's have a wonderful history of doing such. please nobody buy these pos lugs
McGard Splinedrive is the best style to buy.
There are others that have copied this style if you want to save a few bucks or get them in a different color or something.
Gorilla and Muteki are a couple off the top of my head.
where to buy:
google/froogle
http://www.evasivemotorsports.com
masonholmes
Post by masonholmes »
What exactly are you guys doing... I've got the Kyokugen's and see no stripping problems. Also, I believe a 16 (or 15, can't remember) will also fit on the lugs... :roll:
1993 MX-3 ~ SE * 2.5L Swap'd
1993 RX-7 ~ Rotary Performance Built
1996 MX-5 ~ M-Edition * Topless, Daily Driver
masonholmes@hotmail.com
JWMX3
Post by JWMX3 »
Yeah McGuard Spline drive lugs are what i have and im pretty sure you can get em in bronze or gold
Custommx3
Site Administrator
Post by Custommx3 »
Any weight you can save helps, but not always.
I was watching a show on Speed channel a while ago and they put a bigger brake kit on an RSX. Even though it was lighter than stock, they lost horsepower. They determined the rotational mass was causing the loss of horsepower. They even called an engineer to verify this. Even though you say.. 1 pound isnt alot.. it does matter I would suspect because it also is rotational mass.
TsiMiata
Post by TsiMiata »
Custommx3 wrote:Any weight you can save helps, but not always.
Makes perfect sense. The further the spinning mass is from the center of rotation the larger the effective weight will be. I'm sure those brakes had aluminum centers with a cast iron rotor. Since the rotor is the heavier part and was moved further from center its effective weight went up.
TsiMiata
Post by TsiMiata »
Just ordered the mcgard spline drives in black from summit. I got the set for the 5 lug cars. The 4 lug set came with a locking nut. I figure since they are all spline drive is there really a need for a locking nut and to keep track of two tools to take them off? These are to go with the bronze Konig Heliums I ordered earlier this week. :D
http://store.summitracing.com/default.a ... C50F3F2%7D
masonholmes
Looks like we've all been reading the SCC that's on the shelf right now. :P Just kidding, lol, but there is an article about rotational mass, talking about lighter but bigger rotors on a certain car, and losing HP at the wheels because of them.
papa roached
TsiMiata wrote:Just ordered the mcgard spline drives in black from summit. I got the set for the 5 lug cars. The 4 lug set came with a locking nut. I figure since they are all spline drive is there really a need for a locking nut and to keep track of two tools to take them off? These are to go with the bronze Konig Heliums I ordered earlier this week. :D
no heliums for you :?
