<img src="http://goliath.frostburg.edu/wfellows0/ ... G_3686.jpg" alt=" - " />
<img src="http://goliath.frostburg.edu/wfellows0/ ... G_3690.jpg" alt=" - " />
In the pic above, notice how there are two screwholes below the adjuster on the left. Thats the up/down adjuster. it had a motor that was used for the 'auto-leveling' system installed in european models. I removed it since I didn't have the auto-level switch or harnesses to get it to work. If i can get some, i'll install it, but until then, its just extra weight & bulk that I don't need.
<img src="http://goliath.frostburg.edu/wfellows0/ ... G_3692.jpg" alt=" - " />
Turns out they don't direclty bolt in. The headlight housing has some excess plastic on the bottom that might need trimming. I didn't trim mine, but I might later on, you can tell in the pics that the passenger one is really flexing the bumper due to the larger gap on the bottom.
<img src="http://goliath.frostburg.edu/wfellows0/ ... G_3694.jpg" alt=" - " />
<img src="http://goliath.frostburg.edu/wfellows0/ ... G_3697.jpg" alt=" - " />
<img src="http://goliath.frostburg.edu/wfellows0/ ... G_3702.jpg" alt=" - " />
Whats sweet about these is they are ONE PEICE. The up/down & left/right adjusters turn the bulb within the housing, not the entire headlight like our stock POS DOT ones. You can easily see it moving too when you turn the screws to adjust them.
They seem like they are bright, but they just spread the light out much better than the stock ones. One of the H4 Osram bulbs was busted when I got them, so I bought a 9003 POS philips bulb for a temporary fix until I reinstall my HID kit or I might just get some Osram bulbs from Germany & sell the HID kit if it doesn't help.
The beam pattern spreads the light out completely across the entire 180 degree's where hte headlights start. I can see the sides of people's cars as I pass them lit up pretty well. I aimed them so they shined pretty far down the road, but it still doesn't seem to shine high enough to blind people's rearviews.
Here is a crappy pic of the beam pattern...i was driving when I took it, hence why its blurry. I'll try to go onto a dark road and take pics of them while the car is parked later. Unfortunately I never got any DOT light pics to compare these to.
<img src="http://goliath.frostburg.edu/wfellows0/ ... G_3718.jpg" alt=" - " />
<small>[ November 15, 2004, 06:44 AM: Message edited by: Gro Harlem ]</small>
