Passing Emissions with a ZE
hey everyone, just wondering... since the KLZE has no EGR how do u guys pass emissions... my guess would be just leaving the K8 ECU and Mani... but is that my only option? other then under the table passing.
<small>[ June 29, 2004, 11:38 PM: Message edited by: Trancelucent ]</small>
-Damian
***if u know of/have a mx-3 GS with a blown engine and live around me... let me know
- babyblueMX3
Re: Passing Emissions with a ZE
yeah it's pretty much your only option..use 94 octane gas too when you'll do your test..reduces emissions
RIP 400whp ZE-T MX-3
Well that is rather ****ty...if those are the only way to pass emissions. But if one leaves the ZE ecu and mani on how badly does it fail emissions? Is it on the marginal pass or complete fail?
Friends are just enemies who lack the testicular fortitude to kill you.
I'm a 2min man in a 1min universe
94 GS - KLZE, Spec2 Clutch, Fidanza 9lbs FW, 2 1/4 full magnaflow exhaust. 145WHP / 147WTQ
- babyblueMX3
ze ecu = no egr = don't pass emission tests
the millenia IM has EGR right? so then if i got that, all i would need to do is have the K8 ECU when emissions time came... right?
oh and is there anyway u could modify ur ze ecu to accept EGR... or is that just way to hard/expensive?
<small>[ June 30, 2004, 11:31 AM: Message edited by: Trancelucent ]</small>
-Damian
- babyblueMX3
the millenia a-spec manifold yes have egr (that's the one I currently have) but the j-spec doesn't (eunos 800)...sure if you use the k8 you should be able to use egr
Keep in mind the K8 EGR sucks *** and hardly ever pass emissions.
also wouldnt you be sacrificing power buy running the K8 ecu/mani, and is that the intention when doing a ZE swap. NO.
the easyest way to pass the e-test is to swap on a FORD valve cover from a probe.
then when you go for your e-test, tell them its a hot-rod and you need a hot-rod test, show them the engine with the ford valve cover and tell them its a 2.5 from a ford probe, and that was never a factory option (obvously).
the other way to pass, is to have a good cat, and a working egr system.
if you have a ZE computer and need your egr to work, you can hook up a micro switch to your throttle (like for nitrous) and have it set to activate at 1/4 throttle, then have the switch acivate a relay that will activate your egr solinoid which will open your egr valve.
just remember to disconnect it after the test.
Yes, I AM a bastard
Yes, I AM a bastard
if im telling them that its a hotrod and that i swapped the engine y couldn't i just say i have a ZE? is it illegal or something?Originally posted by curtklze:
why is telling them "its a hotrod" make it different?
sorry if im asking stupid questions but every other car ive had has been able to pass emissions...
<small>[ June 30, 2004, 09:33 PM: Message edited by: Trancelucent ]</small>
-Damian
- johnnyb
if you put on the ford valve cover its more obvious that its not stock
![Image](http://i49.photobucket.com/albums/f292/amun931/mx3.jpg)
So could you swap the ecu for the e test and then swap it back after providing you have the intake with the egr valve.
Also someone asked if the ze ecu can be programed to accept the egr valve and make it work, was never really answered, can it be done?
MARCUS
