GS 0-60 times?
A forum for Drag Strip/Track Racing Discussions. (NO Street Racing or Kill Stories, they WILL be deleted.)
hgallegos915
GS 0-60 times?
Post by hgallegos915 »
Whats the normal 0-60 on a stock k8 manual tranny mx3??? I need this to make sure i have my car tuned properly and aligned and all that, also i wanna know to check if im running rich, assuming this would slow me down.
-hec
osargeant
Re: GS 0-60 times?
Post by osargeant »
I believe it is around 8.6 secs for the GS V6 version of the MX3
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
Macen
Re: GS 0-60 times?
Post by Macen »
8.5 secs
Black '93 GS-RL KL-DE
White '95 RX-7 Type R Bathurst
http://macen.nullnet.com
mx3man83
Re: GS 0-60 times?
Post by mx3man83 »
I think its between slow and really slow.
My Cardomain site
lok
Re: GS 0-60 times?
Post by lok »
i dunt think u can do it 8.5 .....thats with like perfect condition stuff and clutch.. and perfect shifting too... i think around 10 secs..
mitmaks
Re: GS 0-60 times?
Post by mitmaks »
car stats says 9.2 or something like that but i know its faster, mine is anyways, depends on engine, how beat up it is, tranny, clutch and most of all DRIVER
killerpickle
Re: GS 0-60 times?
Post by killerpickle »
if you shift at redline and dont shift to third gear, it should hit less than 8.5 seconds.
Tom Alexander
lakersfan1
Re: GS 0-60 times?
Post by lakersfan1 »
A broken in car is faster than a brand new car. There's no way in hell my car's takes 10 seconds. That's automatic Accord 4-cyl. territory.
torpedan
Re: GS 0-60 times?
Post by torpedan »
I wouldnt knock accords that much some of them would suprise you.
Either way stock mx-3s are not quick 10 seconds does sound way more accurate than 8.5 I could see it being in the mid to high 9s though.
-torp.
I don't own a Mazda.
lakersfan1
Re: GS 0-60 times?
No way in hell. If you're running that slow to 60, your car needs a tuneup, or you're shifting like a granny. Especially considering you only need one shift to get to 60 - it'll do a little over 60 MPH in second gear.
hgallegos915
Re: GS 0-60 times?
I was noticing that. Usually 2 or 3 gears is all it takes..
-hec
mitmaks
Re: GS 0-60 times?
Post by mitmaks »
then they whine in Tech forum "my tranny doesnt work, whats wrong?!?!" :shrug:
torpedan
Re: GS 0-60 times?
Post by torpedan »
1992 Mazda MX-3 GS 9.2 16.8
1993 Mazda MX-3 10.3 17.6
Guess it needs work out of the box. Rings dont last forever. Most of the motors on this fourm are not in there prime's either.
source btw:
http://www.albeedigital.com/supercoupe/articles/0-60times.html
lots of fun info to look ta there too =]
<small>[ August 17, 2004, 02:34 AM: Message edited by: torpedan ]</small>
-torp.
lakersfan1
Re: GS 0-60 times?
That still seems too slow. My old 93 Sentra XE could do a 9.2 0-60, and the GS was made to compete against SE-R. I seem to remember the GS being a couple tenths behind the SE-R. 9.2 for the GS sounds more like its 5-60 time, not 0-60.
Nallboy
Re: GS 0-60 times?
Post by Nallboy »
Wow! I got addicted to that site. I was comparing my est. 14.5 w/ modded ZE to some of those times, and it looks like a stock early 90's Mustang Cobra would be around the same times! Then again, where are you gonna find a stock Cobra that's not driven by some I'm-past-forty-but-I-still-want-to-look-young-so-I-got-a-facelift-and-a-new-car type?
'93 GS sporting 31 ZE, 36 ECU, Millenia IM & TB, Beefed up tranny, Fidanza FW, CM Stage II-R, Al UDP, HS Headers, MF Hi-Flow CAT, 2.5" Piping, CAI, MGC Wires, MS Mounts, B&M SS, Bronzoils, SS B & C Lines, Brembos...more.
Oh yeah, I have a stock ATX 92 RS too.
"Everyone wants to live life in the fast lane; I have more fun weaving through traffic."
Return to “Drag Strip/Track Racing”
