ractive/toucan rear strut bar installation
craftydarren
Has anyone here installed the Toucan REAR strut bar? I cannot seem to get both holes (both holes on each side) to fit over the two bolts on the strut on the car. I can only get one hole over one of the bolts. Is this the way it is supposed to be? There are actually three holes on each side of the strut bar but there are only two bolts on the strut top on the car and I assumed that the strut bar is supposed to go over both bolts for stability.<p>So has anyone installed this thing over both bolts? I think soundomain.com sent me the wrong rear strut bar.
16" ASA wheels, Yokohama Prada Spec 2 tires, Tokiko Premium struts, H&R Lowering Springs.
- monty73741
Re: ractive/toucan rear strut bar installation
first thing is you need to cut square, triagle or what ever shapw you like out of the seat belt support...then i should fit....or switch the bar around maybe its backwards
jason
jason
Jason Danaher
Please Help Support MX-3.com
marshmallow15
are the holes in a triangle form? if so, you got the wrong strut bar.
- team slideways
- team slideways
that's what i did, got the wrong bar. bent the poo out of the brackets to make it fit.
eunosads
this is a differert STB.. but this page may help.. <p>http://members.optushome.com.au/eunosads/rstb.html<p>@ds
- EUNOS 30X -
marshmallow15
here's what you can do, drill new strut tower holes into the bar.<p>actually, if its triangle shape, the top is already taken care of. mount the top hole, and mark a place on the other side for the bottom hole and do that to the other side of the strut bar and you're good to go. you may have a few empty holes but who cares it'll be covered up.
- team slideways
- team slideways
craftydarren
Ok it sounds like I got the wrong bar. The holes on mine are in a triangle form. I'll have to think about if I should return it or drill holes...
mazdamxstyle
ya I had the EXACT same problem, got the same 3 hole strut bar and I just bent the strut bar mount to fit, it works and looks great, not worth the return IMO I had pics up somewhere else but dunno where. anways good luck returning it or installing it. And you did get the wrong bar, ours is only supposed to have 2 holes on the mounts not 3.
1993 Mazda mx-3 GS - Blaze Red (Totaled) Went through an 89 rx7 and a 93 del sol. Now searching again!
http://www.cardomain.com/id/mxmisl
i got mine on without drilling. just bent the hell out of the brackets. i just had my friend re-weld them to make sure they're solid
mazdamxstyle
ya the bar you got is the same one me and paragon got, the mount has 1 to many holes and it seems like it shoudl fit and the length is right but its just slightly aimed wrong and the holes arent exact, it definitely is the wrong bar because I had same problem, you could probably bend it and be fine its not to hard to install the one you got compared to the one you should have got.
