Springs & Shocks for a `92 Mx3
Hi
<P>I am looking around for lowering parts for my mx3, and have a hard time finding any good info (except here).<BR>I want the car to be really stiff, but I don`t think I can afford Ground Control coil-overs... (shipping to Norway is expensive.. not to say I have to add 24% taxes on the cost of the part...)<P>I see that the Tokico blues sounds good, but when I look at their page, it says it cannot be used by mx3`s with ABS... doesn`t the US version of the Mx3 have ABS?<P>anyway, I was thinking of the red Koni`s & Eibach combo. will this be much stiffer than stock? and will it lower my car so it makes a difference?<P>I can get a Mazdaspeed shocks & spring kit. Would this be the best performing combo?<P>/ nope-mx3<p>[ December 01, 2002: Message edited by: nope-mx3 ]
Re: Springs & Shocks for a `92 Mx3
The mazda speed struts are well thought of, it's probably your best bet for a stiff ride. <BR>From what I've heard the tokico blues can't handle stiff springs. The ZX2 struts are good, but require modification....<P>Sorry I can't help you more.
tk1138<P>There's not really anything I want to say over and over.
Eibach springs arent too stiff. If you want stiff, you gotta go with coilovers.<P>WHY do you want stiff?
-93 MR2
#129 E-stock
#129 E-stock
I want the best handling I can get, without forking out bigtime. I want to be able to go around turns as fast as possible, with little bodyroll.<P>I found Mazdaspeed springs that was recommended for use with the mazdaspeed struts. They are made by Eibach..<BR>Do you think it`s the same as the Pro-Kit?<P>they where said to lower 30mm, and the Pro-kit is less, I believe.<P>nope-mx3<P>Ps, thanks for all the input guys. It`s much appreciated!<p>[ December 02, 2002: Message edited by: nope-mx3 ]
Then get tires. You can every last suspension mod on earth. It still wont equal the gain from a GOOD set of tires.<P>Bodyroll doesnt effect how fast you can go around a corner...simply how well it will deal with bumps within that corner.
-93 MR2
#129 E-stock
#129 E-stock
I got tires
<P>215/40-17 Goodyear eagle f1`s<BR>Just lacking a decent suspension system.<BR>Just talked to the company that could get me the Mazdaspeed kit, and the Eibachs in that kit was made by Eibach on the specs from Mazdaspeed. So they are probably a lot stiffer than the Pro-kit. (I hope)<P>nevertheless, it should be a major difference from stock struts & springs no matter what
<P>nope-mx3
nope-mx3, are you lowering you car as well? I have a 92 GS and i want great handeling as well, but i also want to lower it. Are/Can MazdaSpeed Springs/struts available to lower your car that are performance struts as well?<P>If i hafta go without lowering my car to get the best performance springs/struts thats fine, but ideally i would like to lower it about 1"<p>[ December 03, 2002: Message edited by: Nd4SpdSe ]
Hmm, Mazdaspeed springs lower it by 30mm, and they are recommended with the mazdaspeed struts.<P>I think I`m going with this combo. Should be killer I think
<P>nope-mx3
i think so too
, unfortunately winter just hit, and what a first snow fall that was, half a foot in under 24 hours, so looks like i'm gonna wait until spring
What kind of prices are you getting for the MazdaSpeed kit? and where?<P>Thanks
I get the complete kit, struts & springs put on my car, for about $1200.<P>This is Norway... Shipping is a killer :/<BR>The parts alone is about $900 I think.<P>nope
nope-mx3, where did you order your parts?
protogests is right. with different tires you can improve handling. after you get tires i would recommend getting larger sway bars for the front and rear. that should give you an enormous boost in handling and still maintain stock ride height and suspension travel.
I just wanna know cause i have to replace my rear struts and just pricing some options for spring, Along with a KLZE swap. <p>Today, its sounds like i need my right drive shaft replaced, funny, i replaced my left about a month ago...i'll change that when i get my brakes done in the next few weeks<p>nope-mx3, where did you get your parts?
