Hey Everyone,
Ok now I haven't looked back into the records but what kind of numbers can you expect to put out if you turbo a GS 1.8 engine? I'm just wondering, a friend of mine wants to turbo my car for me (works in a shop) so I can keep up with his custom turbo Probe (that thing is fast...dyno'd at justtttt about 300 whp) But seeing how you guys have prob tried this b4 what's your suggestions!
thx,
Tyson
Originally posted by seneca: I'm just wondering, a friend of mine wants to turbo my car for me (works in a shop) so I can keep up with his custom turbo Probe (that thing is fast...dyno'd at justtttt about 300 whp) haha
Which Probe? The first genwith the 2.2L 4Cyl or did he do a custom turbo on a 2nd gen with the 2.5l v6 on the newer ones?
1992 Mazda Mx-3 GSR - 2.5L KLZE : Award Winning Show Car & Race Car ['02-'09] (Retired) 2004 Mazda RX-8 GT - Renesis Wankel : LS3 Coils, BHR Mid-Pipe + Falken RT-615K 245/40r18 2011 Mazda Mazda2 GS - 1.5L Manual : Yozora Edition (1 of 500) 2003 Nissan Xterra SE - 4x4 Supercharged : 2" Body Lift, 4" Suspension Lift & 33" MTR Kevlar 2001 Nissan Frontier SE - The Frontrailer : Expedition/Off-Road Trailer Project
A properly tuned 1.8 turbocharged has power enough to give you lots of fun! If you go a little larger on turbo size and piping (although you can always modify that) you have your system capable of doing the 2.5 swap, and you would have earned good experience on delivering with a turbo engine, so you probably won´t blow the same things you may have blew on your K8 on your Kl engine!! I´ll reccomend you that!
I've got a 2.2 powered mazda mx6. I've blown 4 motors due to lean tuning. I used to have a saab .42/.48 T3 on it, and with a cracked piston and compression of 55-90-90-95 I put down 180 whp and 249 ft lbs at 10-12 psi. I'm also 5200 ft above sea level. If anyone is interested I can post the plot.
Anyways, I gave up on the mx6 and decided to make it my daily driver. My mx3 is getting a 2.5 KLDE and a .48/.60 T3. I was thinking of running nitrous too but the KLDE have pretty wimpy rods and cast pistons so I dont want to push my luck. Nevertheless, in the near future you will see a 2.5 turbo powered mx3
98 Ford Ranger 3.0L
