CT26?
BLINDMAN INC.
CT26?
`I NEED TO KNOW IF I NEED TO ADD ANTHING INTERNAL
TO ADD A CT26 TURBO OF A TOYOTA SUPRA ?? LIKE CAMS OR ANTHING ..
Re: CT26?
I thought the CT26 was off of the toyota MR2 and Celica AWD turbos (since they used the same 3SGTE engine). I would think they wouldn't have enough output to be used on the Supra.
Re: CT26?
well i pulled it off a supra slant six engine not sure what yr..but on the turbo it says toyota ct26
.. well how much boost do thay put out if anyone knows .. an will i have to change cams or anything if i put it on ?
92GS.KLze 2.5 ,CT26 TURBO,40K MILES,Ram air intake,2.5 cat back,coming.pullys,cams,Pistons,
valves & springs,venom injectors.
Re: CT26?
well, I can't really tell you which cams or anything to run. Consult the forced induction forums, and there is an interesting article in the V6 FAQ you should check out if you are looking to turbocharge.<p>I believe the MR2 turbo puts out 14psi stock, and 16 on some modified CT26's. It is a rather quick spooling turbo though.
Re: CT26?
well thanks for the advice..it shouldnt hurt if i dont change my cams its going on a 2.5 an if its around 16psi boost i shouldnt have problems..i got it for $20.00usd with only 37k miles on it so i think ill keep it ..
Re: CT26?
The CT26 is the turbocharger used for the MKIII TT supra. I'm sure it would work fine for your V6. <p>P.S. Please tell me if you can get the other turbo. If you can I would LOVE to have it. I have a CT20 on my truck that is blown and I need a replacement. Thanks.
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
Re: CT26?
im sure i can get tons of turbos but the only reason i got mine so cheap is because the supra motors bottem end was shot..
Re: CT26?
And the owner never took into consideration the price he could get for the turbos, piping, ecu, or IM?!
Re: CT26?
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by billy:
im sure i can get tons of turbos but the only reason i got mine so cheap is because the supra motors bottem end was shot..<hr></blockquote><p>you said you got yours for $20, and since the supra has two of them, I was wondering if the other one was there. I can get ANY turbo for $50 if they can find one. It's just the CT26 is a somewhat rare turbo. If you could hook me up with one for $20 that would be awesome.
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
boostedmx
Re: CT26?
that year supra only came with a single turbo. the ct26 was ran on the flip up headlight style supras(cant remember what generation).
Re: CT26?
Okay, I was thinking it couldn't be the third gen supra. That was the second gen you're thinking of, I6 3.0L (or is it 2.5L, bad memory) single turbo
Re: CT26?
You're right. I was thinking the MKIII had the CT26 and the MKII had the CT12, but the twin turbo used the CT12 turbo. My bad. Sux for me tho. I got excited.
<p>But, you got a damned good deal. Everywhere I look for the CT20 I get prices like $450 if I send mine in to get fixed, or $900 for a new/refurbished item.<p>[ February 17, 2003: Message edited by: VizualXTC ]</p>
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
Re: CT26?
CT26 still is a good turbo, the MR2 about the same powerband as the MX-3. I mean, the horsepower usually drops off at 6000-6500
Re: CT26?
ok the CT26 turbo is an AWSOME turbo. My best friend has a 88 celica altrac. It comes with a ct26. This car is amazing. It is a great turbo, it will support 10x more psi then you can ever use, on the stock mx-3 motors. Good choice.<p>Dominic
RIP 95 rs
Re: CT26?
It can take abuse because it was made for daily driving. If you get one with low mileage, or rebuild one, it should last you a while.
