How do you get those black things around the bulbs out?
I read on somebody's website that they did this and that it really made the lights brighter. However, he said that he needed a lot of heat to melt something (he said he had three blow-dryers on it). There's no way in hell I'm going to hold three blow dryers on the lenses. Anyone know of an easier way of removing those things. Also, is there a purpose to them. Do you think a shop would do it for cheap if I was already getting something else done there?<P><BR>-Josh "Light Me Up" Blair.
My anti-drug is <I>bourbon</I>.
Re: How do you get those black things around the bulbs out?
what i did is took the light out and with a screw driver and a pair on needle nose plyers and some side cutters cut and bent and unscrewed the thing trough the hole where the bulb goes
<BR>took me about 45minutes per light
- David Witherow
how was the light output after words
more of a straight beam rather then spread out
<A HREF="http://www3.sympatico.ca/ocd/mx3/headlamp.htm" TARGET=_blank>http://www3.sympatico.ca/ocd/mx3/headlamp.htm</A>
<A HREF="http://www.finchuck.com" TARGET=_blank>Finchuck Online</A>
