V6 Probe Throttle body?
xXx_OTEP_xXx
Post by xXx_OTEP_xXx »
I'm wondering if a throttle body from a V6 Probe would fit a stock GS?
Sold my 95 RS "Little Peanut" but she will never be forgotten. :(
Talon_66
Re: V6 Probe Throttle body?
Post by Talon_66 »
Yup, should.
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
lakersfan1
Post by lakersfan1 »
It will, but only if you also switch to a straight neck manifold. It won't work on a MX3 or Millenia manifold because the IAC on the bottom of the throttle body will hit a coolant fitting.
lakersfan1
Originally posted by XxAntwawnxX:
i got the the who probe mani onmy ze. it does hit the coolant hose...but u can fix that easy.
If you use a Probe or MX6 manifold with a Probe or MX6 throttle body, it should clear fine. If you stick a Millenia or MX3 throttle body on the Probe or MX6 intake manifold, then it'd hit again. I've tried both odd combinations, and neither worked. It has to be the right TB for the IM.
Zoso124
Post by Zoso124 »
Mike Evans
Gone:
2fazed
Post by 2fazed »
I've got a Probe Gt throttle body on, I've also got the DE IM on too.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
hgallegos915
Post by hgallegos915 »
what gains would one see to have a pgt im and tb?? if any?
-hec
