V6 Probe Throttle body?
I'm wondering if a throttle body from a V6 Probe would fit a stock GS?
Sold my 95 RS "Little Peanut" but she will never be forgotten.
Re: V6 Probe Throttle body?
Yup, should.
93 GS, KLZE, KL31 ECU, Centerforce Stg 3 Clutch, 2.25" Exhaust w/Flowmaster muffler, OBX Headers, Pheno Spacers, Front & rear X-drilled/slotted Rotors, KVR pads, SS brake & clutch lines, Ractive Filter, H&R Springs, Tokico Blue Struts, 8mm Accel Wires, MSD 6A w/ Blaster 2 Coil, HVAC Indiglo Panel. *Sold*
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
It will, but only if you also switch to a straight neck manifold. It won't work on a MX3 or Millenia manifold because the IAC on the bottom of the throttle body will hit a coolant fitting.
If you use a Probe or MX6 manifold with a Probe or MX6 throttle body, it should clear fine. If you stick a Millenia or MX3 throttle body on the Probe or MX6 intake manifold, then it'd hit again. I've tried both odd combinations, and neither worked. It has to be the right TB for the IM.Originally posted by XxAntwawnxX:
i got the the who probe mani onmy ze. it does hit the coolant hose...but u can fix that easy.
- Zoso124
Mike Evans
Gone:
Gone:
what gains would one see to have a pgt im and tb?? if any?
-hec
